I have 2330B in for blown outputs.
The customer was driving two 4Ω speakers and fried the driver board.
I identified the many, many damaged parts.. Some transistors are unavailable so I used the recommended On-Semi replacements.
I even managed source original output transistors.
I could not get the bias to budge from zero. I read on posts here the bias control transistor Q738 (2SC1953) was a critical component that the replacements sometimes didn't work.
I managed to source an original 2SA1953, he also had original 2SA913 and 2SC1913, which were the only other parts that were not OEM.
It worked, it biased... at least for a few minutes then the bias started running away, before I could power it down I heard a snap!
Q736 (2SA914) shorted and took out a number of resistors with it.
I used the KSA1381 replacement. That part is now running red hot, bias is stuck at -12mv.
I've unsoldered and tested every part on the board. The board traces have gotten pretty beat up with all the rework, it is possible I have some fractured traces.
Art this point without a donor board or a new blank card, I think I've hit a dead end.
Any input would be appreciated.
