2385 reconnect PS00 to P400 pin question
sendust
Music feeds the soul
Hi im reinstalling the ps00 on the p400 , on one side of ps00 there are three pins, in the center 4 pins but on the p400 board i see 6 sockets, anyone know which 4 sockets are used, is it just the center 4? I think ive got it 4 center slots.
Hi Dankik, I reinstalled the board but find i only have right channel, does Js03 or js04 affect left or right channel sound. could it be in the wrong pin hole
Hi Dankik, as you can see in the first photo, the board was broken and repaired by a member. I found the center new wires had came off the trace, in the second picture you can see the path i ran the new wires directly to the target pins. Can you see anything wrong, before i ran the two new wires i hade no sound left or right.
Here are the traces from the connector. Each is color coded.
Your 2nd photo seems to look correct.
It seems to be connected properly, any idea on what would cut out the left channel, does any of the 4 coded wires affect the left channel, , could the pins be off by one notch, there are 4 pins but 6 slots? or am i barking up the wrong tree. pete
Make sure that the 6 sets of cables to the correct places. Also, make sure that you do not have the connector plugged in backwards. It should be keyed or pin 1 marked with an arrow or notch. There should only be one cable with 4 conductors, the others have different amounts of wires. (See diagram below). That 4-wire cable should come from the P400 board connector J415. Unless, your tech modified it improperly from before?
I will check all of the connectors, i was trying to confirm JS03 that connects to J415 could not be the issue with no sound on left side ,on AM FM or Phono thanks pete
I reconnected the PS00 to the P400, I have both channels on Aux, phono. phono 2, AM. FM signal works but no sound either side. Does the PS00 have any affect on the FM sound signal or has something else happened. Also is it possible to reset frequencies, after reconnecting string something has changed and my dial is way off. Also i notice on AM setting AM light and tape light comes on, on FM setting AM FM and Tape light come on. thanks pete
The PS00 board does contain the FM MPX noise filter circuit and switch. All of the signals go through connector JS02. Check to make sure that you connected it correctly.
Make sure that all of the Tape Mon and Tape buttons are not pressed in.
Make sure that your dial string path is correct. Also, I think there is a screw that tightens the Drum to the tuner capacitor shaft. If that is loose then the tuner capacitor will be off. Usually the dial pointer is attached to the dial cord with some glue. Is that still attached?
Just confirming the 7 pin connector in my photo is the one we are talking about, if so i think its right, do you know which pin on J03 or J04 would connect to the FM, if non of those i must have another issue. pete
Yes. You should have 0v on pin 7 and 14.7v on pin 6. (UPDATED photo)
Also, check the ECB voltages on transistors QS01 and QS02
I get 0 vlt on pin 7 and 13vdc on pin 6. if i turn volume to full i can hear the station playing but just a little , does the outer metal case need to be on for proper grounding? Lastly there is a hum on both channels on fm, sounds like ground. pete
Can you please check the ECB voltages of QS01 and QS02 (dotted red box). They should be as shown above in the schematic.
Which leg do I test? --- Test each E=emitter, C=collector, B=base for the two transistors.
Can I use chassis for ground? --- Yes, you should be able to use the chassis for ground.
Be careful not to slip the probe and short something out.
As per photo
Your voltages on the schematic. All look OK.
Maybe QS02 is questionable because the base voltage and emitter voltage are the same. There should be a ~0.7v voltage drop due to the diode drop.
Check for a short between the emitter and base on the PC board, or shorted RS04?
Check to make sure that the FM Muting push switch is OFF and that the MUTING LEVEL control on the back of the receiver is on minimum.
QS02 no short, RS04 no short but as you see in the photo there is a dead short between the pins i marked on the photo, not sure if that is connected normally
