It seems like the green piece is stuck to the wafer, i can wiggle it a bit but feel it may break the wafer if i pry any harder. Do you think it is fused due to time, if so do you believe heat will help it sperate from the wafer?From looking on the internet, it looks like you might be able to slide the front metal plate with the threads off (green arrow), then remove the wafer (orange arrow).
The shaft looks to be attached to the rotating board with the brass spring contacts that slide on the carbon traces on the other layer.
Hi again, ive tried with a bit of force but nothing is moving, . As you can see in my photo there is a slot at the end of the stem, it is not needed for the knob, The knob slides on and fastens with a set screw. Is it possible the stem is screwed on? .If your control is constructed similar to the one in this photo, my guess is that you can pull out
part 1 - bushingpart 2 - resistor waferpart 3 - contact wiper and shaft... as one piece from part 4, the can housing. Gently see if you can pry it loose where the red arrow shows between the wafer and the metal can
Once these are removed maybe you can see what is keeping it held together.
Watch this video on how to take apart a volume control that looks almost identical in construction as yours.where the volume stem meets the first pot there is a thin copper or brass ring, do you know how its removed to get the cover off of the first pot?
I can see the tabs that touch the wiper in the bad pot, seems like great contact. when moving volume up all is good untill half way, then it goes OL and then numbers are crazy, down after half way almost perfect.Maybe start by taking the back section off first?
Reverse of the way they assembled it.
Also check that the rivets on the defective one make proper contact with the carbon traces.
Yes its the first pot behind the stem, right channel. Its not bravery ,i dont have a choice, it doesnt work.Hopefully you knew which section was bad! You're a braver soul than I am...![]()
I removed the retaining ring before i started to disassemble. The front piece when pulling moves forward past where the retaining ring was but soon as it hits the shaft its a dead stop. I tried to hold both sided of the wafer and push the stem forward but it feels like it hits something, maybe i can use penetrating oil if its some kind of build up but it seems like there is something inside that is smaller than the shaft.Are you sure that you can't remove that retaining ring on the shaft, then slide the front metal piece and wafer off of the shaft from the front?
Under high magnification I can see a black collar or ring in the piece i am trying to remove. there is no way for me to get a tool in there to remove it. It stops it soon as it hits the wider portion of the shaft. I think the only chance is remove the clips on the other side. I also realized the clip i removed on the shaft was not to remove anything, it is spring steel to keep pressure back to the wafers.Maybe the shaft needs to be rotated to a specific position to allow the front piece to slide off?
