Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Has anyone used the 30hz test tone cd when replacing the surrounds on Watkins 12" woofers. Does it matter which VC to send the signal to. Also where can I obtain either a cd or mp3 of the 30hz tone. Thanks.
I've done it before. I just chose the VC with the higher impedance to make it easier on my test amp but other then that I didn't over think it. I have some 30hz test tone CDs that came with my refoam kits but I just use this software instead.
If you have a smartphone and an 1/8 inch to RCA cable (who doesn't?), there are frequency generator apps. I found that out when I lost my Rick Cobb CD.
Thanks for the tip but OvenMaster sent me a 5-minute long, 30Hz sine wave 320kbps constant bit rate mono .mp3 test tone. I downloaded it and burnt to a cd.
