UPDATE - Revision
Okay, been working more on this Record Clamp Design.
Nearly burned out on this project, so may pause here for a minute.
First for the original "flat bottom" design, I have a re-designed "Screw Collet."
Revised part is slightly longer for more thread length.
Slightly bulked walls for strength and added more "shoulder," so split lines dont terminate at the "threads," again for added strength.
Next, I have designed a "recessed bottom" version, printed it in blue.
This has the recessed bottom for use with a "washer," a la JA Mitchell type clamp.
This version has a shorter "screw collet" to be recessed properly, uses same "knob."
This recessed bottom presented a "print issue," which is further compounded by my desire to stick to a "conical shape."
I had to use "supports" for the recess, which made for a print finish inside the recess I aint 100% happy with.
Kind of an inconsequential surface, but still not super happy with it.
I tried printing it upside down to avoid supports but the angle of the cone is too great for my printer to do nicely.
Could just make the plate more of a "cylinder shape" and avoid all that, but isnt that the crux Design/aesthetics vs produce-ability
IF one had a dual head machine with "soluble support" it would be ideal
Have some new material on the way, next print will most likely be done in Glow in the Dark material.
Files will eventually make it to Thingiverse, but if anyone wants the files in the meantime PM me and let me know which version and file type is wanted and where to send them.
Going to have to start thinking about "next project" so if anyone has any "audio related" suggestions, I am all ears.
And thank you to everyone for the kind words and overall reception to this project.
Ben
