4-way RCA quality switch
Raphaz
AK Subscriber
I’m looking for recommendation for a quality switch - minimum 4 RCA inputs and 1 RCA output. No need for volume control. Smaller is better. No added noise or sound coloring. Literally just switching between sources.
I use it to switch between sources like CD player, turntable and tape deck.
From the switch it goes to a Wiim Pro+ and from there to an amp/receiver.
That way I can sync and correct latency between wireless and wired speakers with the Wiim app (the Wiim also serves as a steamer for music services).
I currently have a cheap Amazon PROZOR RCA 4 Way Bi-Directional RCA switch/Splitter (with Volume Control) and I’m looking to replace it with a better quality switch that does not degrade sound or add noise.
No audible noise from the Prozor - if anything maybe slightly compressed highs, but that may be just my perception. The rotary knobs certainly feel cheap though.
Any recommendations appreciated.
Thank you.
Not too many options really, can easily make your own. I use an Adcom slc-505. They come up occasionally. You can bypass the volume and balance controls with the switch on the back.
Thank you, loudnoises.
I’ll watch out for the SLC-505.
I’m not comfortable DIY-ing one, I’m not a tech by any means - you don’t want me near a soldering device.
Thanks, AudioAvarice!
I guess you meant the AS-4III?
It’s a bit pricey for a switch, agreed. The layout with the push buttons on top not ideal for my setup, but if clean, no coloring, noise or loss, it may be worth it.
How do the push buttons work though? I’m assuming it will prevent more than one pushed in at a time (fine w/me)? And no pop when switching?
Thanks again!
There are several Chinese versions from Nobsound, Solupeak, etc. that are quite reasonable. Whether they affect the audio can only be determined by testing and I doubt if any testing has been done. Most of these gadgets are available on Amazon so you can buy and try and if you don't like it, return it. Here's the Solupeak
I am not fond of rotary stacked switches. I would rather use DP DT by-forcated SWC lever switches my self. But, I suppose SWC interlocking push button switches would work.
Thank you for sharing. Hard to be confident about quality at this price. Do you think it’s superior to the Prozor I currently have?
I don't know the Prozor, but for that price what do you have to lose? I like these switches so much that I use 2 of the 8 into 1. I use them on my main sound system with 16 decks/players going into my amp. I have been using these multiple times a day when I'm home rotating my various units, and they have never failed, plus the buttons still lock rock solid. What can I say, I'm impressed.
True about nothing to lose - except for time and the “just-try-and-send-it-back” being a bad habit in many ways. But may be justified for this one.
You might try asking for one to be built for you in BT. I have a few homebuilt pieces and all are top quality.
I had exactly what you asked for built by @Snerp but I think he is not around anymore. I use it to choose from multiple TT into one preamp input. A few of the cable makers could help likely. Also we have fine SUT makers that would be able, if willing, to do this.
GL.
I used to use a Zektor HDS4 to switch between multichannel analog audio sources. It would, of course, work fine for only 2-ch too. I think these were like $500 back in the day.
Since it was originally for high quality component video switching it also handled the analog audio with no problems.
Have to keep an eye on ebay, et al, though.
You asked for advice, and I gave you what I thought was good advice considering that I had almost 5 years of good experience using these switches. Good luck on whatever you decide!
I've used the same switch with a single-input passive attenuator, and it worked perfectly with a phono preamp, DAC and CD player attached. OP don't judge it on price, unless you are looking for a piece of audio jewelry (it is not that)
Thank you all. I’ll pick one and will try it out. As mentioned, worst case I’ll send it back.
