4N fastener puzzle
PE9ZZ
Event Horizon
I'm looking for replacement screws for my Japanese-made Philips 22AH180 tuner. These are self-tapping Phillips pan head screws with 2.9 mm diameter and 1.1 mm thread pitch. They are similar to #3 screws but have narrower thread pitch because they are intended for use in metal. The manual lists 4Nx7 and 4Nx5.5 sizes. And 6Nx7 which is obviously larger, about 4 mm diameter. This suggests metric like M3. Which incidentally is also used in this tuner...
So the question is: which fastener type should I get that will fit?
I'm not looking for a screwdriver, I'm looking for a screw. A fastener, if you will. Looks like the type I'm after is #4-24. 24 TPI is a thread pitch of about 1.1 mm, #4 is 2.9 mm in diameter. Let's find out if my local hardware store here in Amsterdam has something fitting. It might happen!
As for screwdriver, I found that Pozidriv PZ2 fits rather well in JIS screws. As always take care the screwdriver doesn't cam out. My Philips doesn't use JIS screws (no dot).
In some cases depending on thickness of the metal.. I've reamed using a new screw and made formed a new thread i.e. if I can get the lead pitch to grab and get a turn on it I can back off and ream again, soft screws won't work alternative is a set of taps and even though you don't drill you can cut cross threads enough to hold.
Just an idea.
But that would be a last resort. When I got the tuner all original screws were gone and screws were used with the wrong thread. Fortunately the ham-fisted barbarian that damaged the threads of only five holes was also lazy. Not only left out 15 screws, he also didn't tighten them enough to cause serious damage. Fortunately I had the right screws in my tray and by carefully testing identified them.
