I LIKE MUSIC
Yes, very well done!
Commandeered the Wife's craft table for my set up.
To remind all because it's been like a year, the task was replacement of a dual n-FET (the "mixer" FET103) since it was 3 ohms drain to source and presumably shorted.
Acquired Signetics 40673 on the recommendation of dr*audio. Did final check (is this really the right transistor? where am I in danger of screwing something up in the tight space?) and then desoldered the original 3SK-39, trying hard not to break anything else. It was non-trivial... some of the coil wires, particularly, are really tiny. This was right after I desoldered the drain...View attachment 1234764
The old FET had a plastic jacket, likely to isolate the can from other circuitry (the can is and is supposed to be shorted to the source, near as I can tell). I removed it and fitted it to the new FET... probably didn't matter, but why not?
Followed instructions to attach source first, then drain, then the gates (plot twist: the schematic showed gate 1 attached to what was in the actual stereo the gate 2 circuitry... I followed the actual stereo connectivity, obviously--based on what I could discern it shouldn't matter, but it would actually have been a more complicated deal to slavishly try to match the schematic, so why do so?).
The soldering went okay. One thing that went wrong near the end was on reattaching the L103 coil wire: can't tell if it broke or if the insulation melted and flowed over the end of the wire, but I had to strip the insulation back in a space where no wire strippers could get. Ended up cutting it with my fingernails and pulling the insulation snippet out using two pairs of pliers [shudder]. I think it's shorter now, but what're ya gonna do?
Best I could do. Made sure I checked all solder joints with my ohmmeter to verify they were getting connectivity on both sides. Checked drain-to-source resistance: 115 ohms. Much better than 3. Checked overall tuner power supply to ground resistance: 143 ohms. Better than 83 ohms (previous value).
Time to add power... I plugged the 5000X in, set to AM. Verified the expected 14V at AM incoming, then grimaced as I turned the Selector to FM, half expecting popping noises and to see the magic smoke released. Nothing. So far so good. Checked incoming power to the tuner. 14V... if you'll recall, before the FET replacement, it was like 6V. Yet another small victory.
Turning the tuning dial gave me very little on the signal dial... but wait, was that a fluctuation? Eff it, speaker time... and lo and behold, real actual sound. Plugged in an antenna (okay, so it was just a couple of alligator-clipped wires), and... tears of joy...
She works, folks. It's a lovely thing, and I have you guys to thank for the inspiration and guidance.
I still have some stuff to do... while the FM STEREO indicator fluctuates in and out, pressing the FM STEREO ONLY button in basically kills any station, even if it's at Signal 4 or above. Would love some advice there; suspect it's either some kind of alignment issue or something in the demux circuitry...
But overall, I am proud to flip the middle finger at the service shop guys.
"Unserviceable" my ass. Unserviceable no more.![]()
There you go!! Excellent job, I can see you exercised some patience and were thinking about what you were doing every step of the way....
Everything is serviceable, if you have the motivation!!
So good to see you nailed it..
I'd say you need a bit of an alignment which would probably bring back the full stereo function..
I like seeing this sort of thing happening......just brilliant!!
I did find two stations on the dial which were apparently good enough to keep working even with FM STEREO ONLY depressed, so i'm sure you're right.
Just don't have the right signal equipment for an alignment (signal generators).
Still, it's a delight to hear right now. It's so clear!
Great job! A couple of pointers:
Coil wires can be stripped by melting the enamel off with solder. In the factory they just dip the end in a solder pot and the enamel melts off and the wire comes out nicely tinned. You can just touch the iron to the end of the wire and keep feeding solder into it until it melts. I used to scrape the enamel off with an exacto knife until I learned this trick.
You can align the front end for sensitivity by using radio stations and looking at the signal strength meter. Align the coils for the low end of the dial and adjust the trim caps for the high end of the dial. Follow the directions in the service manual, but use stations at the low and high end of the dial.
The discriminator has to be aligned with test equipment, so don't touch it.
You can align the MPX section using a scope and an FM station, adjusting the coils for the max reading on the scope. But leave it alone for now and do the front end. That may fix your problems. The discriminator adjustment also affects how the MPX locks in. Sometimes you can get the discriminator adjustment close by tuning to a place with no signal at all (hiss only, no digital beeping) and adjusting the coil that the service manual says to adjust for centering the tuning meter so that the meter reads dead center.
Come for a holiday down to New Zealand, I'll do it whilst you're enjoying our wonderful country!!
There you go!! Solution right there...Soooooo tempting. En Zedd is on my bucket list.
Dude, I'd like to come and stay there permanently.Come for a holiday down to New Zealand, I'll do it whilst you're enjoying our wonderful country!!
Hmmm... after making a go at trying to trim using the Signal meter I think I might get this thing professionally aligned. There wasn't much change except for the worse when I tweaked any of the coils, and I just don't think I have the precision to make a play at it without equipment. It's odd... some of the stations which come in heavy on the FM Stereo signal are at about 3 on the Signal meter while several that come in at 5 on Signal won't light up the FM Stereo indicator more than intermittently.
What are you using for an antenna? Usually no change except for the worse means it's aligned properly, try using a decent antenna and see what it does with a good signal. If you can get some TV "rabbit ears" they work great for FM.
Sounds like an issue with the selector switch.This is entirely a good point, and I'll pick something up, but the Sansui 800 and 5000A ten feet away are pulling solid stereo with no antenna at all.
Something weird is up, as even when I've got AM selected I get intermittent FM STEREO indicator flashes on the dial.
