Pretty sure he's responding to my comment about output tube cathodes.Pin 3 of the GZ34/5AR4?
Is there something connected to pin 3 on the rectifier's socket?
Thanks!
Thanks!
Not sure what exactly you're calculating. Sounds like the discrepancy in cathode resistor values likely a matter of whether there is one resistor per pair of output tubes or one resistor on each tube. When a shared cathode resistor is used, it handles the current for two tubes, so for the same bias point half the resistance for two tubes that you need for individual resistors on each cathode. 11 volts across 180 ohms is 61mA for two tubes, half that per tube, with 296 volts across the two that's 9 watts dissipation. If you're getting 11V across individual 330 ohm cathode resistors, that's 33 mA or just under 10W dissipation with the same plate voltage. I may be misunderstanding what you're asking.Addendum..remembering back to the restore. I could not get a Pilot 240 schematic WITH the simpli-magic test panel used to set bias by sound and/or voltage. My schematic says 180 ohm cathode resistor. This amp with the test panel has 330 ohm cathode resistors. I’m getting 11 volts on the cathode. 11 volts on cathode and 307 volts on plates. 5.1 watts??? Should I leave it alone.
yes, though its not a linear relationship. Meaning if you make the resistor 10% smaller, it doesn't necessarily mean that the current increases by 10%.You could bump that voltage up by lowering the cathode bias resistor? And vice versa?
