Maxxarcade
Here's my documented rectifier failure/replacement timeline for my fully restored Scott LK-72A:
Unit was placed into service on July 28th, 2006.
JJ GZ34S - arc'd at 78 hours (38 days) after installation (Sep 5th 2006). Arcing noises became present intermittently well before that time. Tube was scrapped (then, I found out it was under warranty for 90 days.) DOH!
Installed on Sep 9th 2006 - JJ GZ34S - arc'd at 65 days after installation (Nov 12th 2006). Noises actually became present intermittently after about two to three weeks. Tube was kept after replacing.
Installed on Nov 14th 2006 - Sovtek GZ34 Cryoset - arc'd at startup!!! (same day) then appeared to be fine with some intermittent noises for 93 days (Feb 15th 2007). Noises increased and started about 25 minutes after startup until it eventually made those arcing noises almost all the time.
Installed on Feb 19th 2007 - JJ GZ34S - arc'd at 42 days after installation (Apr 2nd 2007). Noises were occasionally intermittent during that time. Tube was scrapped since it was happening nearly all the time after a month of use, and sometimes started making noises about 15 minutes after startup. Also seems to be happening a bit more frequently.
Installed on Apr 10th 2007 - Sino 5AR4 - Noises noticed 4 hours after installation!!! Never actually saw it arc, but I definitely heard it. Rushed into family room to turn off the amp. Tube was removed after cooling thrown into the metal waste bin at my local landfill the following morning. . .with extreme prejudice.
Reinstalled on Apr 11th 2007 - The Sovtek GZ34 Cryoset is currently back in the amp until replacement arrives. Noises are sometimes now starting only about 10 minutes after startup, and are more frequent.
April 27th 2007 - Sovtek GZ34 - Quiet for four days, but now noises are more frequent and can start happening as soon as 10 to 15 minutes after startup.
After putting a 1961 Mullard 5AR4 in there, the rectifier arcing stopped. It has been fine since I pulled all the new production tubes out and replaced them with vintage.
YMMV
. . Falcon
This makes me nervous, because I have a quad of JJ EL84's that I'm going to use on my Zenith amp. Though the 5U4G will be a vintage Sylvania or Philips.
