Hello all,
I just picked up an RCA VMT-72W console for free on fb marketplace. It worked nearly perfectly--the only problem was the (stage) right subwoofer cracking intermittently. It would improve some when you fiddled with the balance knob but never fully went away. When i opened the back the thing was riddled with cobwebs. I cleaned the dust and cobwebs and went through all the wiring connections with some Deoxit. Now, the crackling subwoofer is constant and happens regardless of volume level of the system.
My Attempts to Diagnose:
I am clueless when it comes to all the wiring inside, so I am hoping that someone can offer some diagnostic help based on what i've found. I've attached pics of what I (attempted to) describe above.
Any advice is very much appreciated!
- I first started by swapping the power and ground wires for each of the subs and it swapped my problem (R sub worked and L sub crackled), so the issue was upstream.
- I then messed with all of the connections between the subs and the amp narrowed down to the connector tab where the sub wiring connects to the amp.
- For each side (L + R) there are 2 prongs but only one connected wire. When the crackling sub is disconnected and touched to the free tab on the non-crackling sub side, both sides work and the problem is solved! The only problem is that there is maze of connections unique to each side after these tabs enter the amp, making me feel like there is an electrical reason these 2 sides are separated.
