Those 6336s are some really beefy tubes- but have some rather odd operating anomalies.
One of which, is the imbalance between tube sections. As these were not intended tor audio- there was no consideration given to balancing sections. One of the things this leads to, is biasing problems, if one ever tries to use the two sections in parallel. The only way that can work, is to cathode-bias (with a bypass cathode cap) EACH cathode INDIVIDUALLY. Apparently, it is possible to connect plates in parallel, as long as the cathodes are on separate cathode bias resistors.
Secondly, is the need for INDIVIDUAL grid stoppers. 1K grid stoppers are recommended- but one must use SEPARATE grid stopper resistors on EACH grid, even if the tube is used in parallel.
Thirdly- low-value grid bias/ground resistors are paramount. Some data sheets say that 200K per grid bias resistor is OK- but, realistically, 100K is probably a much safer value.
Fourthly- these tubes, due to very high Miller capacitance and very low gain, need "god's own driver circuit". Both high current AND high voltage. It can take close to 100V AC signal drive voltage, at pretty high current levels, to not wind up with HF anomalies. This is a case, where maybe something with very low plate impedance, like a triode-strapped EL84 as a driver, per side or something like a paralleled 6SN7, per side, could be applicable. You will need probably close to 400V, or so, preferably 450V, for the B+ supply for the driver tube.
Fifth- the 6336 needs to be warmed up (heaters on) for probably 20 to 30 seconds or so, before B+ is applied. Not doing this can damage the tube, causing noise, runaways, and other problems!
OTOH- One distinct ADVANTAGE of using 6336s as output tubes, is that they, themselves have ASTRONOMICALLY LOW plate impedance. This means they can usually drive some transformers, that would badly misbehave on other higher-plate-impedance output transformers. Response anomalies on either end of the spectrum may well be reduced, for output transformers. And, with 30 watts dissipation per plate- a pair of these in a push pull circuit (essentially parallel push pull) should be able to put out the power of parallel push pull 300Bs, on similar output transformers- potentially up to 50-70w per channel. And they may actually have better bass, due to the even lower plate impedance.
Regards,
Gordon.
