Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Thought I would chime in on this thread. I have been using 6P3S-E tubes in my Yaqin MS-20L off and on for two years. The other tubes I have used are Electro Harmonix EL34-eh, Electroharmonix 6CA7 big bottle, Groove Tube EL34, JJ EL34 and the stock Shugang EL34.
I always end up going back to the 6P3S-E, the next closest is the EL34-EH which has slightly better midrange clarity but significantly less bass.
I run the bias between 485-500 mv.
I bought them from a guy in the Ukraine that sells on DIY forum, my wife liked the sound so much she told me to guy another quad "just in case".
That isn't the bias current. You're reading the bias indirectly, through the voltage drop across a resistor. The actual bias current is in mA (milliamps) and is some fraction (probably 10%) of the number you quoted. So your tubes are probably biased at 50 mA.
I bought these quad of 6P3S-E Russian tubes a week ago.
I put them in my beloved YAQIN MS-34B in place of the KT88 and began with 20mA biazzz and did NOT expected anything beatyfull at all. But the lower frequenties already began to break through..After a few hours I changed the biazz to 30mA. Tubes need a break-in period so I went to sleep while the music was playing. But it was already clear enough that the tubes did a better job than the KT88.
Next couple of days I set the bias to 45mA and in between and came to the conclusion that the Russians sound best at a biaz of 35mA in my YAQIN
Best in every aspect I mean.
Lesson I learned is that the bias not always has to be set to the highest possible vallue. In my case the tubes sounded much better at 35mA, than at 45mA bias
