Hi,
Is it possible to use 10M45S as cathode current source in 6SN7 LTP shown on schematic? From simulation it appears that cathode bias voltage is only about 10V and I don't know for sure if this is enough for depleted mode mosfet.
Another option is a 10mA constant current (limiting current) diode like LM334Z (40V/400mW max, which seems enough). Currently have no data how LM334Z (which was designed for power supplies) will behave in audio circuits.
Thanks in advance for any suggestion(s).View attachment 2677687
To use CSS you will need a negative power supply. 10M45S requires at least 10 volts to enter operational range. In circuit you show grid is at ground level. in that case cathode is only few volts above ground. This is not enough to make 10M45S work. I would say it is not enough to make any CSS work when you consider cathode voltage swing.
