You can still get a lightning adapter for those 30-pin connectors.
I saw a stereo preamp that used a pair of classic 12AX7 phono stages and a pair of 12AU7 for the line stages. Looks like that should work.That there using 12ax7 + 12au7 together. That I thought is strange. Usually it's one or the other. Maybe one set is the dummy set (just glows).
Wut dey put in dem tings? Crack it open and have a look.I thought a 12ax7 and 12au7 combo would be weird for a preamp.
Let's crack it open and see what we got.
I could be wrong but I believe these were also labeled under the name "Fatman" iTube amps or probably made by same China factory? Many thousands of Fatman hybrid tube amps similar to this amp with iPhone/iPod docks were sold, they were all the rage on eBay & Amazon about 15 years ago (dare I say) helping the tube market make a mainstream come back.
Sounds like the OP has the knowledge to get this unit in tiptop condition and working. Has to be hybrid IMO, I need (4) 84L's to get that output, but then again I'm not very smart. Watching and hoping the OP gets it up and going!
I got a cheap one of Amazon. It works.You can still get a lightning adapter for those 30-pin connectors.
A piece of digital history!Yes we do. Something that came across my bench recently speaking of Apple. Its now alive and well again.
Yup. It still had all the original software, manuals and paperwork.A piece of digital history!
Interesting. Do you know the part number of that 3M tape?Yup. It still had all the original software, manuals and paperwork.
These old Apples have a very common failure problem. One of the small 3M tape pieces was.put right over the solder pads of an I.C. chip. The glue on the tape corrodes the board over time. I cleaned the board, replaced the solder and it fired right up.
I should have stated 3M type tape. It's padded and was used to space or insolate the back side of the main board from the housing. Maybe used to reduce vibration? I have some 3M brand tape like that I bought sometime back, but it's two sided tape. Whatever Apple used back then, the glue turned brown.Interesting. Do you know the part number of that 3M tape?
I'm betting that the MacInstosh wasn't the only electronic place that tape was used.
