I did a small evaluation of 7199 replacements in a dynaco sca35 where a small number of tubes were tested.
Two groups of measurement : dist at 1 5 and 15 w output power, and voltages around the phase spiltter where
Va(p) = voltage at penthode plate, Vg2 = voltage at penthode screen and Va(t) voltage at triode plate. These
voltages shows how close the working point is from an ideal cathodyn phase inverter. No components are
changes only the tube is replaced. A EFB equippped SCA35 was used, with a matched quad of JJ EL84.
Instruments used is hameg 8027 low distortion generator and hameg 8037 distortion analyzer.
http://n.manet.nu/tubedoc/sca35-7199-alternative.pdf
GB-1252 ECF80 and ECF82 used 2 samples, 6bl8 and 6gh8 i had only one of each at the moment of test.
Looking at this small sample ecf80 seems to give lowest overall dist, even slightly better then 7199
( i had a number of 7199, screening them showed no significant differences among individuals)
Note that SCA35 has a DC stabilizing function the most likely reduced the DC differences, in the future
repeating this with a ST70 might show larger differences between tubes. I just have to wait until an unmolested st70 is available for testing.
