7868 & 7591 Tubes
I have only had one 7868 tube go bad on me in the last five years and the one 400 that I sold used to see
about six to eight hours a day of use, when rebuilt and in good working condition those Fisher 400 amps
do get good mileage out of the output tubes although I don’t push them hard I use them for lower volume
listening, if I need loud volume I switch to the Hafler DH-500 for that purpose.
If you watch the online auction site closely you can find the Sylvania 7868 tubes under other labels such
as Conn or Dumont and sometimes get them a little cheaper.
12ax7 tube are plentiful and still easy to find although some of them can get pricey, I have also heard the
Telefunken tubes can last up to and even more then 50000 hours.
I do use a thermister on the 400 for a soft start, I think that helps the tubes too.
Based upon 7 hours per day x 365 days x 5 years= 12000+ hours for the 7868s- nice. I am good with spares. I also backed up all other tubes with one spare. All tubes were NOS rolled in for best sonics.
Sovek 7591'sare repinned 6L6's.Most the time your not running your amp at full power, so there is plenty of drive for the outputs. I have not heard of any complaints of Sovek 7591's notworking well. A fresh driver tube is always important. Biasing is a little different,even new tubes need bias adjustments. 6L6's work good under avarity of conditions,that's why they are so popular.
I think for my 7868 amps, if I didn't have hoards of old tubes I'd replace the sockets and run the EH 7868. I've used it a few times and so far so good.
The EH7868 as others stated needs the grid resistors reduced from 330K to 200K. To restore the sonic response it is suggested to change the grid coupling caps to .1uF. The Fisher 400 ERO coupling caps from germany are hard to beat sonically. I think the reason the EH7868 can run away with 330K grid resistors is the vacuum does not meet NOS specs thus grid leak occurs. But, only a guess.
The EH7868 as others stated needs the grid resistors reduced from 330K to 200K. To restore the sonic response it is suggested to change the grid coupling caps to .1uF. The Fisher 400 ERO coupling caps from germany are hard to beat sonically. I think the reason the EH7868 can run away with 330K grid resistors is the tube internal vacuum does not meet NOS specs thus grid leak occurs. But, only a guess.
BTW- why does AK have such an issue uploading to site? Sorry about double post.
While the original original Sovtek attempt at a 7591 (7591xyz) was a re-pinned 6L6, the current production 7591's from EH and JJ are more electrically true to a 7591.
Interestingly the 7355 is essentially a 6L6 with a 7591 pinout. The Sovtek 7591xyz actually makes a pretty good replacement for the 7355 where it will fit (anything wired to pin 4 would need to be relocated, or pin 4 cut from the tube).
I like both the 7591 and the 7868.
I've tried most of the output tubes now in amps.
7591, 7868, 6BQ5/EL-34, 7189, 5881, 6L6xx, 6CA7/EL-34, KT-XX (not the 90 or the 120), a few of the also-rans like 6973.
More and more I feel like it's the power requirements of your speakers and the implementation in the circuits, trannies, and where the tubes operate on their conductance curves that make the bulk of the difference in a working system.
The output tubes seem kind of like a last mile issue like resistor formulation (metal film, carbon film, carbon comp, etc.), coupling cap types and tube rolling.
You can run the whole race, and you must run it competitively to be a contender, but it's the last mile that matters the most in where you finish in the race.
Both the 7591 and 7868 were designed late in the game, they both provide a lot of power for the bottle size, and they both work well in well designed circuits.
Oh, and Jay, I agree with you about the KX-200. I find it competent but uninvolving. I do have one here that will grace the bench soon. I bought some coupling caps from Russia. I wonder if the green K42Ys will liven it up a bit. They seem to throw a great soundstage and that may be what the KX-200 needs to liven up.
That's very curious. What makes you think the 7591 is a 6L6 internally? Can one use the same datasheet values used on the 6L6 to adjust the bias on a 7591 amp?
I think he means the Sovtek 7591 is not really a true 7591, but simply a re-based 6L6 tube. You might get away with subbing a 6L6GB or GC with proper socket re-wiring but its not quite a one for one replacement. Here's some data if you're interested
http://www.triodeel.com/7591.htm
The other option is of course a socket change to take a 7868. Electrically the same, just a different connector really. The EH and vintage ones work for this, but the EH pins are fatter and really go for a different socket. NOS use a Novar socket, EH use a Magnoval. In my book, I'd go for a socket change vs messing with the circuit just to avoid drilling out some rivets. Either way you are modding the thing, so why not keep the same power output?
Short answer is no. You would be pulling the tube's response out of design center values to the detriment of sound quality- theoretically speaking.
Inernal connections are the same, but operating voltages, bias voltages and current values differ between the two in the same topology.
If the Russian tubes mentioned actually were 6L6's, they would have had a track record of failures quickly unless the tubes were actually constructed to handle the higher currents and potentials. And there have been a few.
I've used both the EH 7591 and EH 7868.
The EH is not a repurposed 6L6.
I do believe that EH reused the 6L6 bottle for the 7591's innards.
JJs have infant mortality problems and a lot of those may be because of manufacturing tolerances inside the tubes. The bottle is somewhere between the size of the traditional 7591 and the EH 7591. I've heard stories of filament sag on JJs during shipping or storage and dcgillespie has stated in a test that they do not perform as well as other 7591.
Making 7591s the old size inside may be the manufacturing difficulty.
Some will just lament that they just don't make them like they did in the old days.
My thoughts are that either the manufacturing materials required to make the innards small are too expensive to bring the tubes in at a competitive price, or they may be outlawed or have waste disposal cost issues.
Be that as it may, the EH 7591 is a 7591. Put it next to a 6L6 and the bottle size will look similar but the innards are different.
Hi Jay - sorry to put this, but I'm having trouble getting through with PMs. Tried to send a few but maybe they aren't arriving?
Trying to get in touch re: the 6DJ8 tubes you expressed interest in via PM in BT.
Could you shoot me a PM?
I'll try PMing you. I had forgotten about those smoky devils.
As far as 7868 RCA vs Sylvania, I've got a pair of monoblocks that use each kind. To my ears, the RCA grey plates outperform the Sylvanias. But to be fair, I don't think the amps are identical as far as passive components.
That is what I understood when I got a new set of EH7591 for X202B a few years back. A shame the wood case is now too tight a fit because of the bigger bottle, but otherwise very nice tubes. My impression was that they were more "modern" sounding than the tubes they replaced but can you really judge the actual sound difference between tubes when using samples that are decades apart in useage?
That one Fisher that got used six to eight hours a day was only used for two years, I sold it a
few years ago and was using a second Fisher 400 with different output tubes for the other three
years, it was the second 400 that I had one output tube fail but I was pushing it very hard when
that happened.
Those hour calculations would be less then 12000+ hours because two units were involved in that
time frame, still they do get good mileage from output tubes if you don't push them very hard.
When I got the second Fisher 400 it was a parts unit and in very bad condition, I took it all
apart and replaced some tube sockets that looked like somebody took a ice pick and gouged at
them, the front glass was smashed out and the tuning dial and FM circuits were badly damaged too,
chassis was very rusty and pitted it was a real nasty looking thing when I first got it.
I used the amp to experiment with I removed all the FM circuits and altered it to use as just an
integrated amplifier, it ended up sounding better then my clean 1st 400 and my Dads 400 and now
it's my keeper.
Some pictures of what it looks like today.
The on off switch was broken so I added the toggle switch on the face and the amp meter so I could
always see the current draw, in the one pic you can see the crazy looking frames with the bank of
Mallory capacitors hanging inside,on the left side those are shielded cables with RCA jacks that
are tapped directly to pin 7 at the phase inverter tubes,and yes there are 470K resistors to ground
at pin 7, I am experimenting with an external preamp (just a linestage with no tone controls)
bypassing the stock Fisher 400 preamp and that definitely has improved the imaging and soundstage
even more then with the stock preamp, it has more bass punch too.
is there a diagram or list somewhere that compares the function of pins in a 7591 vs 7868? In other words, if I know the grid pin on one, where is the grid pin on the other?
