I'm doing some research into some anomalies I found in an 800-C in a '63 Executive and am developing a theory about the service manual numbering.
What i'd like to get from anyone with an 800-C or an EXECUTIVE MODEL 950 (1963) or EXECUTIVE 960 (1964) is the following:
1.) SERIAL #
2.) POWER TRANSFORMER Part Number off the Physical Transformer.
3.) OUTPUT TRANSFORMER Part Number off the Physical Transformer.
4.) Which manual you used to work on your 800-C (Need the series numbering at the bottom or side depending on the design of the front page.)
It beginning to look like the 1963 EXECUTIVE Model 950 has a slightly different 800-C than the rest of them. Transformers are slightly smaller in laminations but endbells are larger(numbers are different), and the NFB circuit is different than any of the other manuals. The '63 Executive had a manual with a series on it that was not used anywhere else in the 800-C run. The '64 Executive used the 30001-39999 or 30001-49999 manual (they are the same). Which leaves us with the 20001-29999 series. I believe that the 20001-29999 series is the standalone series for 1963. With FISHER consolidating the Console and standalones in 1964, the numbering then makes sense.
I think this would go a long way to dating our individual units. So please write down the info and post it. I'll collate it and figure out how to make a spreadsheet(never needed to before now) with all the info on it.
Also if ANYONE HAS a manual with series numbers on it OTHER THAN the following please let me know. Eventually I want to put them all into the AK DATABASE in order.
10001-19999 (Exclusively Model 950 Executive)
20001-29999
30001-39999 (960 Executive is same)
30001-49999
Larry
1.) SERIAL #
20001-29999
30001-49999
Larry
