800-C & 63'/'64 Executive owners PLEASE READ!!!!
Larry,
you'll need a variac for this. If you don't have one, let me know and I can let you use one of mine for a few days.
Tom
Wasn't sure.....knew you were the king of the Dim Bulb Testors......but thought I recalled that you were in search of a Variac some time back. Guess you found one!!
Happy New Year Larry......let's hope for a good one!
Tom
1964 fisher 800c data
serial # 46692Q
power transformer 1991-115c (9264379)
output transformer 1991-116-2c (9264379)
This were all of the numbers I found on the transformer bells I used a copy of the service manual supplied by metal bone for serial numbers 30001-39999
I hope this is helpful!
Looking for an output transformer.
Here are mine. I only have one output transformer. Please! If somebody has an extra one will really like to buy it. I really would like to rebuild this 800c. Thank you.
Ssun; Best to look on EBAY for a parts unit, or a separate transformer. Don't limit yourself to the 800-C. The 500-C uses the same transformer as the 20001 and up 800-C. You can become a subscriber on AK for $25. and get access to BARTERTOWN, which is the AK Flea Market. No Fees, and the guys know how to pack better to survive the Gorilla's in the brown uniforms.
You could also try HEYBOER transformers in Michigan. They rewind and build transformers. You'd need the spec's on the transformer HxWxD, turns ratio, etc. but they can do it. and fairly cheap too.
Larry
I'm in!
Serial #
33493D
OPT's
T991-116-2A
(9263446)
Power T
T991-115B
(9263444)
Original Service Manual
20001-29999
However I used the appropriate manual from AK doc library for restoration. :thmbsp:
Martin
