xeizo
don't run it like that!!!!!!
Needs to be on a level surface right way up.... You will render the liquid refrigerant filled heatsink useless
Ok, thanks for the advice! :thmbsp:
Temporarily fixed:
Had to replace a few protect relays over the years... A big cause in your units is dirty input select switches.
Over the last 20 years I have collected a SU-v5, SU-v9 and both have developed issues with a channel cutting out
My latest acquisition (last year) is a SU-v505 and the dreaded channel cut out is starting on this unit too. :sigh:
Really love these amps to bits, but it seems hard to get a 100% working one nowadays.
Anyone else had this problem with theirs ??
The sample of the V4X I talk about here actually had similar problems already when it was new back in the eighties, but in this case I think it had something with the protection circuit to do. It never came out of protection at about 3-4 years of age.
Luckily I knew a radio serviceman who replaced some component I don't remember which for the owner back then, after that it has been working for some 25+ years and obviously still is.
Less than perfect quality control, and some components on the cheap maybe? Anyway, old amplifiers of ANY brand usually develops problems ...
Spot on!
They are the switches indeed. They ran them via steel controller cables to minimise interference to the signal path
Yes, relays can fault, and dirt and oxide affects any old amp. A thorough cleaning can do wonders, but it doesn't make switches and pots new as the cleaning also removes some of the original protective layer which makes the need for cleaning more frequent over time ...
So some switch cleaner on said switches required?
Most definitely. There are some good threads on this somewhere
Those particular types V8 V9 ~ V909 can really get bad over the decades... Like some heavy duty tarnishing happens
Cleaning is the only option, as they're long time unobtanium
I recently picked up a Technics SU-V98 that appeared clean, powered on, and sounded clean. At home it seems to work but is limited in volume. The volume knob rotates around and around with no increase in volume beyond what is a a conversational level. Is there some sort of protective circuitry that governs the volume so it will not overdrive the speakers?
It is not a bad little amp, perfect for a small room. It gets plenty loud but this "feature" of a volume knob that has no stops and goes round and round with no increase in volume beyond a certain point is curious. I don't have a user manual and the online service manual does not explain this. What is this?
