Ok. Which types do you find better?Ncore? Not even close to the best.
I hope this doesn't turn into something like the "damping factor" thread.![]()
Looking at an Usher R1.5, it is 89 lbs, 150 watts per channel at 8 ohm, guessing the first 25 watts is in class A as the R2.5 is 250 wpc AB/50 wpc Class A. Idle current is at 250 watts for the R1.5. From what I read, the amp is based on Nelson Pass' Stasis design. My Rotel RB-1090 is around 85 lbs but delivers 380 wpc in AB, 0.0000001 wpc in class AThe question is, why build an amp that weighs a ton, idles at 250 watts, but only delivers 150 wpc in Class AB?
Yes.., it is. And yes, it does. I happen to own an Usher R1.5, and it is a very capable and superb sounding piece of gear. It handles my big Infinity speakers and their infamous low-impedance dips with aplomb, all thanks to that big power supply.The catch - it's derived from a Nelons Pass amp. Hence it's big, inefficient and probably sounds very nice.
The large heat sinks also contribute to the weight.
My old 333.5 factory modded Levinson weighed around 150lbs IIRC. Bonus was you could cook hotdogs on it. Bad thing was if you blew anything in it, it was a 150lb doorstop because most folks could not afford the cost to repair if it was possible which is why I sold it before I or something else hurt it
Unfortunately, no.Do you have the service manual for this unit? Need to bias my amp
