Pilotlips
Hello,
Doing a restoration on the Sansui 9090db.
I did a full recap, changed most transistors, resistors, diodes and fixed all threw holes on the dolby board. Naturally also all pots/switches taken care of.
Now without the driver board using a dbt is dim the relay works and get the green protection light.
On the driver board 99% is new, also transistors gain matched but with the board connected the dbt is bright. I know usually this is a driver board transistor gone short (when I got the unit this was the case 2SA599) but all are now new and triple checked.
Now the funny part is with fuse 04 removed on the PS board only then R34 smokes away even with a dbt 70watt. Output transistors are new mj21193 and mj21194 and installed in the correct way. Could there be another problem else then the driver or power supply board or output transistors causing this failure?
So very stuck now, who can give a idea on how to bring 70's beauty back to life.
Thank you
Thank you
