Hmm. TR121 is good at B and E (~50V each), but is at -30V from the collector (should be -1.8V). It tests fine on the multimeter.
Do both ends of that resistor have 50 volts on them ?It measures 22.5ohms and has 50V on it.
ReplaceD121 (HZ16-3L Zener): 4.75V across it. -35V at anode / TR119E. Not good either.
ReplaceD111 (HZ9C-3 9.1V Zener): 0.15V across it, but -36V cathode to -35.3V anode.
ReplaceD109 (HZ9C-3 9.1V Zener): 5V across it. -35.5V anode to -30.5V cathode.
Bad -- Should only be .6 volt difference -- Replace with 1N4148D107 (1S1555): Tests good, -35.5V anode to -30.5V cathode .
Did you replace C173 680µf/85vdc ?
As it should be..Measured C173, I do have 50V on the + side. 0 volts on the - side.
voltage amplifiers back down before proceeding with the diagnosis?
You could but I'm not recommending it.I wonder if I could just swap them between channels for now
