The SB Audigy2 ZS Platinum Pro is what I'm using now, and it's lightyears ahead of the older SB cards in design, construction quality, signal processing, effects, conversions, noise floor, etc. It even uhas an IEEE 1394 Firewire interface which really helps with latency issues between external devices (as long as you have PLENTY of RAM and nice Quad-Core processors in the PC).
As far as the AC'97 is concerned, if you have the very first version of that SB Live! card (in MY book, I equate MOST first version releases of hardware as a 'PROTOTYPE'), then you're adrift at sea standing on a four board raft (probably balsa wood) that measures 3' x 3'; and no paddles to be found.
So, you can't really get to anywhere you'd like, you just have to go with the flow and put up with wherever it leads you. Sure, you could choose to modify the card, but that usually ends up as a very time consuming project with little result in world of having a sense of accomplishment.
Even the EMU10K1-SEF DSP added many anomolies when running it's sample-rate conversion algorithms. It was audible, and it really sounded like crap to the trained ear.
However, were talking about
digital audio here, right? Digital means there's a file full of information about the audio; and where there's a file, there's a way to hack and modify it.
Have you attempted to simply open up a file in an editor program and change the sample-rate information in the header from 48KHz to 44.1KHz? Sometimes, depending on whatever the REAL file type is being created, you can do this.
You could also send me a wavefile, and I could perform a sample-rate conversion on it using one of my mastering software converters. I regularly have to convert from 24 bit @ 192KHz (or 96KHz), down to 16 bit @ 44.1KHz; and with the high-end wordclocks used here I generally get excellent results.
Upload a few through YouSendIt.com to
FalconEddyStudios@MSN.com; Then I'll analyze them, and convert them at the highest accuracy level possible. I have some huge processing power here so even the highest quality conversions are fast. No charge, of course. Then you can download them from a link I'll send you to your personal email, or your private email here at AK.
You can't beat a deal like that. Seriously!
. . Falcon
