a/d/s/ L400e
nathanso
Are the specs for the L400e the same as the L400? If not, can anyone post the L400e specs?
The L400e has a different tweeter and a lower-Q woofer IIRC. It sounds a bit better than the L400 but you should listen to them first and then decide if they work for you.
I already have a pair of L400e speakers. Was just wondering if a low power tube amp would be able to drive them adequately in an office setting.
