Richs_Trains
Well-Known Member
Hey All,
The last unit I worked on taught me a lot as it was the first one that came DOA and I was able to bring back.
I have a few questions to better my understanding:
People refer to the 'main rails' quite often, what and where are they usually located.
This unit (Marantz 4230) lit the DBT when I got it and I found the short by process of elimination. I removed power to different portions of the unit until it passed the DBT and then re-powered them one at a time to check each one. The main problem turned out to be a bad filter cap (first time for me) and at this point I had the power removed from the filter cap and the power from the transformer to the power supply board, it passed the DBT, but I also had dial lights, where was the power coming from?
Adjusting the amp without a scope requires a measurement at the junction of 2 resistors, but they are always sheathed in rubber to stand them away from the board, it there a test point, or a way to remove some rubber to get a good connection?
After learning what the rectifier is and does, is the series of diodes on the power supply boards another rectifier set up?
Can you troubleshoot and repair a power amp with the actual unit (I have two power amps that are not working
that I replaced in units, having them working would offer some spares).
Thanks in advance,
Rich
Thanks in advance,
Rich
