I recently set up the following with a Behringer DCX-2496 active crossover:
JBL 2226H in JBL 4507 cabinets.
JBL 2445J drivers on 350 Hz. Edgarhorns.
I am crossing at 560 Hz with a 6 db butterworth on the woofers and 24 db Butterworth on the horns. (I have already corrected to standard polarity on the woofers)
Here's my question:
A 6db slope Butterworth is 90 deg out of phase and a 24 db is 360 degrees out.
Since I can set phase relationships with the crossover, where should it be?
For whatever reason, in listening so far, it seems to sound best with with the horn set 225 deg out.. (inverted plus 45 deg)
Also, while I don't need CD compensation with this horn, the natural HF roll off of the 2445 seems to lend itself to compensation. Is there a standard fixed Lpad compenation formula to help? At the moment, I am using the parametric EQ function to add about 12db of boost centered at 14KHz...
I think I can use this:
Where R1= 9 ohms and R2=4 and bypassed with a cap.. maybe around 1 uF?
I used 4Pi crossovers when first setup. The electronic crossover is significantly better...
While I am not wild about the dispersion (or lack thereof) of the Edgarhorns, this setup shows serious promise..:yes:
Here's my question:
