Mockduck
Member
The advice has basically always been that a surfactant helps in your record cleaning solution because it allows the solution to get further into the grooves of the record. The advice has also basically always been that if you use a surfactant, you should do a rinse with just distilled water after in order to remove the surfactant from the record.
How, though, does the distilled water get into the grooves of the record to clean out the surfactant if surfactant is necessary to get into the grooves of the record?
