Sonically the AT95E is actually a pretty good cartridge with an even frequency response with good extension at both ends. This is where my audio spectrum analyser was very useful at confirming what my ears have told me through listening, and one thing is for sure, this cartridge likes the so called 'standard' input impedance of 47 k. Its upper frequency response is actually much better than the Shure M97xE at 47 k in this respect where spectrum analysis definitely shows an upper treble roll off! In the case of the M97xE, this treble roll off is essentially eliminated by increasing the phono preamp input impedance somewhat (I use 62 k). However the AT95E seems very well matched at 47 k and it doesn't seem overly fussy with regard to input shunt capacitance.
The output level is judged to be just noticeably lower than the Shure M97xE, which in itself is slightly low output, but in practical terms this isn't a problem as the simple one opamp test phono preamp used in this evaluation http://www.redcircuits.com/Page10.htm the AT95E was able to easily deliver enough equalised output level to drive a following line preamp and power amp into clipping when the volume was raised up loud! Tested on a wide variety of recorded material produced very satisfying and high quality sound with a surprisingly wide and stable stereo image, and no inner groove distortion issues were noted. Compared to other higher priced cartridges, in absolute terms the AT95E lacks only the last ultimate degree of resolution and detail provided by a more exotic stylus profile which on the majority of even high quality systems is probably unnoticed!.
I don't know how long the AT95E has been manufactured for, but its excellent reputation over many years is very justified and well deserved. It's a top little cartridge. Let's hope it goes on being available for many years to come. I highly recommend it! Regards, Felix aka catman.
Wow! I found the same with my AT95E! I don't go that deep into analyzing the impedances and all that, I wouldn't know where to begin. All I can do is listen and judge from that. I have my AT95E mounted to my stock Pioneer PL-510-A (Nice little manual table...I prefer manual tables). I have my Shure M97xE mounted on my stock Pioneer PL-530. Played both through my Yamaha CR-2020 and noticed that the AT95E out-performed the Shure hands down. The Shure isn't bad, but it seems to have a problem with being really aggressive on the highs forcing one to really adjust the tone controls quite a bit. The AT95E on the other hand sounded balanced and I didn't really have to fiddle with the tone controls that much..just a tiny little tweak on the bass and I was there, everything else was neutral. I'm kind of disapointed in the Shure actually. I was expecting something closer to the AT95E from it as it's advertised as an "audiophile" cart and has the brush on it and all that fancy packaging and such. (Turns out it's better to play records with the brush up in my opinion).
Anyway, I'm going to be doing some vinyl digitizing soon down the road and decided to use the PL510 with the AT95E cart. That said, I will have it hooked up to my TC-750CL Pre-amp running through my Sansui 8080db so I'm hoping it will sound great....everything sounds different and fabulous through that amazing receiver. (Have not tried the TT hook up yet though).
I was trying to think of what cart to get for my Denon DP47f and I think I'm deciding between the AT95E or a Grado. Maybe I'll get both.
