Hello and thanks in advance for helping me!
I will be soon overhauling my 1226. I've already replaced the steuerpimple. But I'm still having issues.
1. When I have antiskating set to what I think should be the proper value (same as the tracking force, according to my manual), the tonearm wants to drift to the right when dropping, sometimes even missing the record. If I adjust the antiskating a bit, the stylus will drop properly, but the value isn't the same as the tracking force - I'm not sure is that a problem? Sometimes, when the stylus hits the record, it abruptly jumps to the left into the grooves, making an unpleasant sound. I'm sure that can't be good for my stylus or the record. Any ideas on these issues?
2. When using the auto start, the audio out signal (sorry I do not know the correct jargon here) does not turn on as soon as it should. That is, the stylus will already be in the grooves when something clicks inside, the audio turns on and the start/stop lever shifts back to neutral. I have a feeling something needs cleaning/lubricating - but what?
3. Speaking of lubricants, I asked this in a separate thread, but does anyone know a substitute for Shell Alvania #2 / Gadus S2 V220 AC2 that is readily available in the US? I'd prefer not to spend $50 on lubricants.
4. It seems the idler wheel isn't making great contact with the platter. If I apply my carbon brush to a record, it causes the platter to slow significantly. If I don't use the table for a while, it can take a fairly long time or some manual help to get the platter spinning. Any ideas?
5. Lastly, my 1226 didn't come with a ground cable. I do get a lot of static on records. I use a Japanese anti-static paper mat on the platter. Would you advise to add a ground cable? I read somewhere to attach the ground to the metal chassis. Would this improve the static problem?
Thanks again for your help!
