duckrabbit
Member
Greetings all!
I just bought an Accuphase from the US and shipped it here in Europe (Finland). According to the seller it had been thoroughly checked by a local tech. Apparently the four big caps have been replaced with Nichion LGK Gold, same value as originals. I tested it with an old step down transformer of mine and it seems to be working. However, the step down transformer is not a very good one and only provides for "appliances max 200 watts". So I suspect it lacks juice for the Accuphase. I also suspect this might affect the sound quality: it is very good indeed but it seems to lack some punch especially in the bass - even my Sansui AU-101 (recapped) has tighter bass. This was when speaker damping switch was in the "normal" position.
Now I know very little about electronics. As I've understood, the older Accuphase amps have a voltage selector. It seems that I could just switch the voltage to 240 v by simply switching the jumper. Before I do that, I would like to ask if anyone has done this with the E-202 or if anyone can think of a reason not to do this myself.
As you can see below, I already removed the jumper. Should I just place it to the 240 V position?
Finally, can I just use this power chord and replace the US plug into a 2 pole european one?
