The E202 came to me with one weak power transistor so all got replaced with new MJ21193/4. Was fun to match them with an Atlas and vintage ELV TT7000 tester.
Once in I replaced overheated resistors, out of spec small value capacitors and several 2SC1451 on the Power Supply pcb with KSC2690A as they match the requirements and were available in my parts box.
And more 2SC1451 got replaced: Phono Equalizer Q9 & 10 as well as on both Main Drive pcb Q3 the KSC2690A were used, too.
Now I’m wondering if KSC2690A are the best choice for Phono and Main Drive pcb’s. A good alternative could be TTC004B as it has lower Cob (and is for audio
Any experience you could share how to best care about 2SC1451 on Phono and Main Drive pcb?
