Acoustic Research AR-2A/X Restoration
ThePlague
Hello all,
After finally figuring out what these really were in a previous thread, it is time to restore them. I have never done a speaker restoration myself, especially not something of this age.
To summarize the findings, these speakers are all original and the AR-2 speaker has received the AR-2X upgrade and some point in its life. The other speaker is a AR-2ax and that is what it is internally.
Starting with the AR-2ax, the obvious is that the woofer needs a re-foam. The mid-range and tweeter were not working on this speaker and I feel that is likely a result of the pots needing restored. On this model, is it worth replacing/upgrading the crossover while everything is apart?
On to the AR-2(x), there was no response out of this speaker when testing. Upon disassembly, I pushed the woofer down and after a light crack (I believe the surround sealant had become hard), the woofer is moving freely again. Of note here, when pressing down and letting go, it makes a pop sound when hitting the end of its return travel. I am not sure if this normal operation or not. What is the best product for rejuvenating/resealing the cloth woofer surrounds? I believe this will also need restoration of the pots. Again with this one, would it be worthwhile to upgrade/replace components in the crossover?
In general, what are the recommendations for resealing these back up? I highly doubt that RTV would be a good choice. It seems that original sealant was some sort of grey compound which is surprisingly still soft to this day.
I appreciate any help you guys have to offer! The pictures are ordered such that the first group is the AR-2ax.
Yeah, 50 year old paper caps need replacement. It's not as common on ARs,
but old caps can completely kill midrange or tweeter sound. JKent on CSP
(classicspeakerpages.net) sells the best pot replacement at the best price.
Not sure what's going on with the woofer in the 2x. Could be blown. They're
fairly common, though. Any cloth surround from a 2-series system will work.
The only option that doesn't cause damage to cloth surrounds is the sealer sold
by vintage-ar on ebay or RoyC here. If the putty is still pliable, and you have
enough, it's fine to use it for sealing the drivers to the cabinets.
Looks like someone's already upgraded the pot on the 2x. It might be fine. It
also has the oil in metal caps, which typically don't need replacement.
