Acoustic Research AR-91
cmcvey
Member
Just found a pair of Acoustic Research AR-91 for $150. Worth the price?
Get the impression I could talk them down a bit in price. Would be pairing them with a Marantz 2230 and replacing my Paradigm 5SE speakers.
CM, you may want to post this in the 'Dollars and Sense" forum since you are asking a value question. Not trying to poke at you in any way, just hope to be helpful :)
In my opinion, the Marantz would not drive the AR's to satisfying levels with good bass punch. I like the Marantz receivers, but the AR-91 is rated as a 4-ohm speaker with a minimum impedance of 3.2 ohms. To really enjoy the speakers, you will need an amplifier rated for 4 ohm loads and probably over 100-WPC. You could put your Marantz at risk of overload pretty quickly if you attempted to play the AR's moderately loud. You didn't say if the Marantz had been recapped or not. If it has not-- the risk of damage to the receiver would be even greater. If you are able to close a deal on the AR-91's, keep in mind a higher power, 4 ohm (or less) rated amplifier will probably be required. I would think something over 100 WPC as a starting point. I have a few pairs of AR speakers. I do enjoy their sound. GLWTB. :music:
Thanks for your reply, that's good information. I talked the guy down to $100 and I know it's well worth it but I may pass because I know want to risk my receiver.
The Marantz has not been recapped, just cleaned up with the bulbs replaced. My repair guy said the caps looked fine (Not swollen or anything like that).
If the speakers are in nice condition, that is a good price IMHO. I realize I may have made you anxious about your Marantz 2230 with my previous reply. Only you can decide if you can live with driving the ARs only at low levels until you can obtain a higher rated amplifier. You could buy the AR's and just keep the volume very conservative until a suitable amplifier makes it into your possession.
In my own experience I attempted to drive a pair of Polk Audio SDA-1A's with a vintage Marantz 2250B receiver for TV/AV and some two-channel audio. About the time I was operating the receiver where the SDA's were just starting to get moderately loud-- maybe 30 WPC or so with greater peaks-- the receiver tuner dial and meters' backlights would actually noticeably dim with a kick bass or other strong bass sound. A sign the receiver power supply was running out of gas-- and definitely straining too much. The Polks are rated at 4 or 6 ohms I think. So that would be a similar comparison to operating the AR-91's on a vintage Marantz receiver.
If you purchase the AR's, you would be better served to hold-off using them until a bigger amp is available. That model is, however, IMHO, a nice speaker. The decision to buy-- only you can make that. :scratch2:
Good deal on those for $100. The drivers alone are are worth substantially more than that.
I've owned a lot of vintage speakers, and the AR-91's big brothers the AR-90 and AR-9 are the best speakers I've every owned. Full stop. I'd be falling over myself to buy a pair of 91 at that price, and I'm using a 2230 too.
While I'd agree with the recommendation of a big direct-coupled solid state amp over your 2230 for these, watts are cheap, and the Marantz will make a dandy preamplifier for a larger power amp.
Thanks for the replies. Maybe I will still buy and it just be careful.
GoRNR - When you say amplifier, do you mean receiver? To me I think of an amplifier as something I hook up to my receiver for extra juice but I think sometimes receivers are referred to as amps.. Thanks again for entertaining my elementary questions. :)
A receiver puts three components in one case: tuner, preamplifier, and power amplifier. It's the power amplifier part of a receiver that's rated in watts per channel, and which amplifies the electrical signal enough to drive your speakers.
Amplifier can also refer to an integrated amplifier, which is the preamp and the power amp together but doesn't have a tuner. And of course the word amplifier very often refers to a standalone power amplifier.
You can read much more about all this by doing some Google searches. Also read the stickies in various forums here on AK.
cnolanh - Great info! I'm going to start shopping for a power amplifier.
Hopefully with that I can really crank up the volume without worrying about straining my Marantz.
Thanks again
I had at one time AR-91, great speakers, and for 100.00$, it's a steal.
I would pay 400.00$ to have another pair.
I used to pair them with a SA-8800 Pioneer, 80watts amp, excellent match.
i have the 91's paid 430 for them mint condition and all original also have a marantz 2226b the little marantz's just don't have enough power to drive the 91's i blew the output transistors in mine.i now use a rotel ra-1312 intergrated amp rated at 110 wpc @4 ohms and the 91's can drive it into clipping very easily they are very power hungry,and i would make sure all the drivers work especially the tweeters as they are very hard to find.i just had one of mine repaired at speakerexchange luckily they had a couple nos diaphrams in stock
buy them, use the 2230 as a preamp, and buy a carvin PA amp to drive them....
http://www.carvinguitars.com/products/HD1500
400W@4ohm, made in the USA, $270
The guy said I could come look at them this morning but when I called him he said that he'd also agreed to let someone come see them before me who is driving in from out of town. May of lost this one :(
Hi guys! Jomel68 knocking, i am a newby in AK and glad that i registered and joined.I am fron Sydney Australia, working as a Registered Nurse( Born and raised in the Philippines). I have been a fan of AK , reading forums,until i had the courage to contribute and started restoration, Had Wharfedales that i restored, Kef Concerto, AR 94 and 3 weeks ago was able to buy an AR91 for $50 Australian Dollars.
I want to post the newly started restoration I made. I just started doing so since i work nights and only have 2 days off and a day consumed much on sleeping.
I am posting the speaker and the installment of my restoration, The Foam sorround from the 11” woofer was dried an falling off. Bought the sorround foam and did the refoaming.
