Get that thing out of there and either a) find an OEM replacement on ebay or b) go with the HiVi solution (both cabinets). While I used to be more of a purist about the classic AR speakers, I've found that I like the HiVi tweeters at least as much as the originals....and the price is right.
... Is the fact that it is made in Japan, a good thing or is it still just a cheap tweeter?
It's irrelevant, not bashing Japan or Realistic but it was not meant for those iconic speakers.
@spark1 suggestions are the way to go, as for the crossover and that cap you can deal with that once you get the correct replacement tweet.
Plenty of how to threads here when it comes to crossover rebuild/restore etc
any idea as to keeping the small black “cap” or whatever that is in line if I get the HiVi tweeter? What is the purpose of it? I am not confident enough to to take apart a crossover or even know what I am looking at if I looked at it, would prefer to buy the two tweeters and just hook them up if this is possible.
.. I am not confident enough to to take apart a crossover or even know what I am looking at if I looked at it....
Not possible.
Even if you opt to find an original tweeter on ebay, you will need to verify that crossover is in original configuration.
If you go the HiVi route, you would need to do the same, put an inductor across the tweeters, and optionally add a capacitor.
AR3a is not a set it and forget it speaker, unless already restored.
The HiVis will require crossover mods to sound close to the original tweeters. That cap on the Realistic tweeter is useless.I guess I am confused, if this speaker is working fine with the realistic tweeter, why couldn’t I add the HiVi tweeter in it place without any mods, or does each tweeter require a different crossover setup? I’ve replaced a bass speaker on a pair of realistic Mach Ones and it was just a matter of removing and replacing, no need to change caps or alter crossover.
Radio Shack sold that tweeter for more than 20 years. Yours is probably from June of either 1979 or 1989. Those built in '99 are less likely to have been sourced from Japan.Well, here is the answer…. Realistic !
