adcom AVR
joebeadg
my dynaco preamp was humming so I replaced temp. with an adcom gtp-740. AVR i guess u call it. anyways it sounds bad, thin, no tone controls. Is there a way to make it work for a stereo?
What source are you using? Turntable, CD player etc.
Does it have a direct mode? That usually helps when using an AVR as a stereo preamp.
You seem to be having the same problem I had when trying to use a Yamaha AVR for 2 channel. I tried everything including checking all the settings, and performing a factory reset (which you should try if you haven't already). I eventually came to the conclusion that it just wasn't my preferred sound.
