One note: The speed adjustment will be less going up from each target speed, for instance from 33&1/3 it’s not going to adjust as much up as down…
The circuit in the link you sent might work, I didn't dive into it in detail. I have used a couple of the 555 IC and don't find them to be very suitable for this purpose. In addition to something to generate the sine wave of correct frequency (and being able to vary that frequency), you'll need to amplify it back to 120 VAC with sufficient wattage. I'd go with something proven and designed for turntables. I can point you to a couple threads on DIYAudio if you're interested.
That motor will require at least 40 watts to drive it - bigger than any I've seen before. I'm not aware of any commercial controller that will drive it.
It will be a great table when you're finished and well worth the effort to restore it. Before you go too deep into a motor controller, I'd replace the run cap and clean up the bearings. then give ti a listen. The pitch may not bother you and I suspect the speed will be very constant ( low W&F).
Be sure to allow some ventilation when you build your new plinth.
I agree that the setscrews on the side of each speed are adjustments for pitch. May obviate the need for any controller.
Also, it's probably worth having Terry replace the rubber on the idler.
@Fishead - I'm interested in this device you speak of. Is there a link to the actual product you have that you can post here? I'd really appreciate it. I have been warned that such devices need to be designed to work safely when handling fairly high current levels for these heavy and powerful turntable motors.
Anyone have an appropriate QRK nameplate for sale?
I don't believe this is true with the right controller. You'll have a wide range of speeds - from at least 33 to 78 with the same motor and the proper controller.@Fishead Right. I'm learning as we go here... and from what I've learned, if it's not a variable frequency drive, it won't work. Even with a variable frequency drive, I have to be watchful of motor overheating when slowing pitch down much more than 1 or 2 % according to some I've talked to.
Thanks for your help all the same! If you think of anything else, let me know.
