centsless
I most certainly will.
I made a little progress today. I measured the risers, drew up a sketch and cut some 1x2" oak. I couldn't find oak in 2x4" size, so I plan on stacking two pieces of the 1x2" together to get more height. Even stacked, the height of the oak risers will still be a little shorter than the original risers, but they'll still clear the walnut trim around the bottom. And I plan on adding feet which will give a little more height. I haven't yet decided on feet.
In the pic below, the oak is not yet glued and screwed together, I just laid it out to see how well it matches the factory riser.
ADS L2030 Risers by Audio Database, on Flickr
Good to see you are using the 1x2 oak. Here is a company I have used for pads or glides...... https://www.allglides.com/
ADS L2030 Risers
ADS L2030 Risers
