ADS models, an impromptu rollcall
I made a few corrections to the list.
(Just to be clear: I compiled the current list a while back, but this is the collective work of a lot of AKers. Feel free to copy/paste the whole thing with additional updates/corrections.)
I also started a picture thread to have a record of what these beauties look like.
Golden Era - aDs & ADS - Mid 70s to Late 80s
Early models were assembled in USA from parts produced by Braun in Germany. Over time, more production occurred in-house.
L Series
The two-way Lx20s and three-way Lx30 came before the two-way Lx70s and three-way Lx80s. There is a later, and supposedly improved, “version 2” for all the Lx10s.
Bookshelf / Stand-Supported Speakers
ADS L200
ADS L200cc
ADS L200e
ADS Delta Lab M1 (L200 w/ internal high-pass for nearfield, high-output monitoring)
ADS 2001 (active “L200” type pre-77)
ADS 2002 (active “L200” type pre-84) ADS AW4 (1st plastic housing L200e for outside use) (cabinet shape similar to 2001)
ADS L210 (last version of L200e)
ADS L300
ADS L300c
ADS L300cc
ADS L300e
ADS L310 (last version of L300e)
ADS L400
ADS L400 version 2 (smaller cabinet) (7" woofer)
ADS L400e
ADS L420 (2 way, 2 driver) (7" woofer)
ADS L470 (2 way, 2 driver) (7" woofer)
ADS L470/2 (2 way, 2 driver) (7" woofer)
ADS L10 (2 way) ( 7" woofer) 6 ohms
ADS L1 (2 way, 8" woofer, same as L520)
ADS L500 (8" woofer)
ADS L520 (early) (2 way, 2 driver) (8" woofer) 4 ohms
ADS L520 (later) (2 way, 2 driver) (8" woofer) 8 ohms My L520 is 6 ohms with the bronze metal grill
ADS L570 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L570/2 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L620 (2 way, 2 driver) (10" woofer)
ADS L630 (3 way, 3 driver) (10" woofer) 8 ohms
ADS 700 (2 way, 3 driver)
ADS L700 (2 way, 3 driver) 4 ohms
ADS 710 (3 way, 4 driver) *foam surrounds
ADS L710-A (3 way, 4 driver) (7" woofers) 4 ohms
ADS L710 (3 way, 4 driver) (7" woofers) 6 ohms
ADS L730 (3 way, 3 driver) (10" woofer?)
ADS BC8 (3 way) ( 2x tweeters, 8" woofer) (Broadcast model c. 1978, looks like L730 from outside)
ADS L780 (3 way, 3 driver) (8" woofer)
ADS L780/2 (3 way, 3 driver) (8" woofer) 8 ohm
ADS 810 (3-way, 4-driver) 4 ohm
ADS L810/A (3-way, 4-driver) (8" woofers)
ADS L810 (3 way, 4 driver) (8" woofers) 6 ohm
ADS L880, 880/2 (3 way, 3 driver) (10" woofer) 8 ohms
ADS L910 (3 way, 4 driver) (staggered 10" woofers) (bi-ampable, many used Pioneer XO)
ADS L980
ADS L980/2 (bi-ampable w/ modified C2000 crossover)
Floorstanding Towers
ADS L690 (2 way, 2 driver) (8" woofer)ADS L990 (3 way, 3 driver) (10" woofer) 8 ohm
ADS L1090 (3 way, 4 driver) (7" woofer)
ADS L1090/2 (3 way, 4 driver) (7" woofer)
ADS L1230 (3 way, 4 driver) (8" woofer) (bi-ampable w/ C2000 crossover)
ADS L1290 (3 way, 4 driver) (8" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1290/2 (3 way, 4 driver) (8" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1530 (3 way, 4 driver) (10" woofer?) (bi-ampable w/ C2000 crossover)
ADS L1590 (3 way, 4 driver) (10" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1590/2 (3 way, 4 driver) (10" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L2030 (3 way w/ line array mode, 7 driver) (14" woofer) (bi-ampable w/ C2000 crossover)
L*e/B Series
Late 80s and early 90s bookshelf speakers. B series uses same components as L*e series but with economy plastic housing.
ADS B7 (2 way) ( 7" woofer)
ADS L7e (2 way) ( 7" woofer)
ADS B8 (2 way) ( 8" woofer)
ADS L8e (2 way) ( 8" woofer)
ADS L9e (3 way) ( 8" woofer)
Subwoofer
ADS PB1500 (utilized a C1500 crossover)
ADS PB1500 + 2: L400 (small versions) = SUBSAT2300 (also came w/ F400 stands)
Crossovers
C1500
C2000
Car Audio
ADS 200i
ADS 200is
ADS 300i
ADS 300is
ADS 315i
ADS 320i
ADS 320is (component speakers)
ADS 325is
ADS 325im
ADS 234is
ADS 235is
ADS 236is
ADS 334is
ADS 334px
ADS 335is
ADS 335px
ADS 336is
ADS 336px
ADS 344is
ADS 345is
ADS 345cs
ADS 346cs
ADS 346is
ADS 641px
Transition Years - a/d/s/ - Late 80s to Early 90s
Sticky dome tweeters no longer used. Original engineers had left company.
ADS M9 (3 way, 3 driver) (8" woofer)
ADS M9/90 (3 way, 3 driver) (8" woofer)
ADS M12 (3 way, 4 driver) (8" woofer)
ADS M12/90 (3 way, 4 driver) (8" woofer)
ADS M15 (3 way, 4 driver) (10" woofer)
ADS M15/90 (3 way, 4 driver) (10" woofer)
ADS M20 (3 way, 4 driver) (dual 8" bandpass)
ADS M30 (3 way, 4 driver) (dual 10" bandpass)
ADS Delta Lab M1 v.2
ADS CSAT (precursor to AW4)
ADS AW4 (2 way) (4" woofer, 1" dome tweeter) (plastic housing)
ADS CM5 (2 way) (5 ¼" woofer) (plasti-crete housing)
ADS SAT5 (2 way) (5 ¼" woofer)
ADS CM6 (2 way) (6 ½" woofer) (plasti-crete housing)
ADS SAT6 (2 way) (6 ½" woofer)
ADS CM7 (3 way) (7" woofer) (plasti-crete housing)
ADS SAT7 (3 way) (7" woofer)
ADS Campus System = AW4 + Sub
Subwoofers
ADS SW2 1989 10" Ported
ADS SW4 1989 10" Ported
ADS SW5 1989 Acoustic Suspension, 12" Powered
ADS Sub 6 1992 Dual 6.5"
ADS Sub 10 1990 10" Powered
ADS Sub 12 1990 12" Powered
ADS SW150 1996 8", Not Powered
ADS SW300 1996 10", Not Powered
ADS SW500 1996 12", Not Powered
Late Period - a/d/s/ - Mid 90s
Company is sold and moved from Massachusetts to Arizona.
ADS MV-10/C Center-Channel 1996 Dual Tweeter
ADS MV-15/S 3-Way Dipolar 1998 5.25" Woofer, 2 x 4" Mids, 2 x Tweeters
ADS MV-20U Floorstanding 1996 2 x 7.75" Woofers, 1" Tweeter
ADS MV-30 1998 2-Way, 2 x 6.5" Woofers, 1" Dome Tweeter
ADS MV-30T Floorstanding 1996 3 x 6.5" Woofers, 1" Tweeter
ADS MV-40 1998 2-Way, 3 x 6.5" Woofers, 1" Dome Tweeter My pair are from Wilmington Mass. Told that they are early 90's
ADS MV-40T Floorstanding 1996 2 x 6.5" Woofers, 1" Tweeter
ADS MV-60 1998 2-Way, 2 x 7.75" Woofers, 2 x 1" Tweeters
ADS MV-60T Floorstanding 1996 3 x 7.75" Woofers, 2 x 1.5" Mids, 2 x 1" Tweeters
ADS MV-80 1998 3-Way, 3 x 7.75" Woofers, 2 x 1.5" Midrange, 1" Tweeter
ADS MV-80T Floorstanding 1996 3 x 7.75" Woofers, 2 x 1.5" Mids, 1" Tweeter
ADS MV-100 Powered 4-Way 1998
ADS MV-100T Floorstanding 1996 2 x 10" Woofers, 2 x 1.5" Mids, 1" Tweeter
ADS R50i/C 2-Way Ceiling 1996 5.25" Woofer, 1" Dome Tweeter
ADS R60i/C 2-Way Ceiling 1998 6.5" Woofer, 1" Tweeter
ADS R80i/C 2-Way Ceiling 1998 8" Woofer, 1" Tweeter
ADS S-500 1995 5" Woofer, 1" Dome Tweeter
ADS S-600 1995 6" Woofer, 1" Dome Tweeter
ADS S-700 1995 7.75" Woofer, 1" Dome Tweeter
ADS W/C 300AX Architectural Loudspeaker 1999 2-Element, 2-Way In-Wall, 5.25" Woofer, 1" Tweeter
ADS W/C 400AX Architectural Loudspeaker 1999 3-Element, 2-Way In-Wall, 2 x 5.25" Woofers, 1" Tweeter
ADS SPK W/C 800AX Architectural Loudspeaker 1999 5-Element, 2.5-Way In-Wall, (4)5.25" Woofers, 1" Tweeter
ADS AVF 144 1995 2 x 4" Mids, 1" Dome Tweeter
ADS AVS 140 1995 4" Mid, 1" Dome Tweeter
ADS AVT 148 1995 8" Woofer, 2 x 4" Mids, 1" Dome Tweeter
ADS AW 4 Indoor/Outdoor 1995 4" Woofer, 1" Dome Tweeter
ADS AW 500 Indoor/Outdoor 2004 Bass Reflex, 5.25" Midrange, 1" Tweeter
ADS AW 600 Indoor/Outdoor 2005 Bass Reflex, 6.25" Midrange, 1" Tweeter
ADS CM- 50 2004 5.3" Woofer, 1" Tweeter
ADS CM- 60 2004 6.5" Woofer, 1" Tweeter
ADS CM-250LCR 2004 2 x 5.3" Woofers, 1" Tweeter
ADS HT300 2001 Passive, 5.25" Woofer, 1" Tweeter
ADS HT400LCR 2001 Passive, 2 x 5.25" Woofers, 1" Tweeter
ADS W/C C 60i/S 2-Way In-Wall 1996 6.5" Woofer, 1" Dome Tweeter
ADS W/C C 80i/S 2-Way In-Wall 1996 8" Woofer, 1" Dome Tweeter
ADS W/C C300i/S 2-Way Flush-Mount/White 1990
ADS W/C C400i/S 2-Way Flush-Mount/White 1990
ADS W/C C750i/S 3-Way In-Wall 1990 7.75" Woofer, 1.5" Dome Midrange, 1" Dome Tweeter
Subwoofers
ADS MS 1 7" Subwoofer 1995
ADS MS 1U Subwoofer 1996 7" Driver, Not Powered
ADS MS 2 8" Subwoofer 1995
ADS MS 2U Subwoofer 1996 8" Driver, Not Powered
ADS MS 3 10" Subwoofer 1995
ADS MS 3U Subwoofer 1996 10" Driver, Not Powered
ADS MS 4 Powered Subwoofer 1996 12" Driver
ADS MS 4U Subwoofer 1996 12" Driver, Not Powered
ADS SW150 Subwoofer 1996 8" Driver, Not Powered
ADS SW300 Subwoofer 1996 10" Driver, Not Powered
ADS SW500 Subwoofer 1996 12" Driver, Not Powered
ADS AS10S Subwoofer 2001 Sealed, 10" Woofer
ADS AS10V Subwoofer 2001 Vented, 10" Woofer
ADS AS12S Subwoofer 2001 Sealed, 10" Woofer
ADS AS12V Subwoofer 2001 Vented, 10" Woofer
ADS C10ps Subwoofer 2004 10" Woofer w/150W Amp
ADS C12ps Subwoofer 2004 12" Woofer w/300W Amp
Might be Semantics but the Big boy 910 do not have an L designation.
That being said here are my current and past list of ADS. Smallest to largest.
SW4’s
L-200’s
Noel 300’s
L-300’s two pair
L-400’s 2 pair
L-500’s sold
L7e’s
L-520’s sold
L-710’s early cloth grille sold
L780/2’s 3 pair
BC8’s fully refurbished
L-1090/2 sold
L-1590 in rosewood
910’s
And a
PB-1500 with c-1500
also have an
R1 receiver and a
Model 10 amplified acoustic dimension time delay unit.
thanks
BT
SW4’s
L-200’s
Noel 300’s
L-300’s two pair
L-400’s 2 pair
L-500’s sold
L7e’s
L-520’s sold
L780/2’s 3 pair
L-1090/2 sold
L-1590 in rosewood
910’s
And a
PB-1500 with c-1500
also have an
R1 receiver and a
thanks
BT
Nice assortment you’ve had. What’s currently in your stable?
Glenn,
Still have all but the ones listed as sold.
I might have an issue
also have a pair of M-15’s that are in pieces need to veneer them as they were stripped of their black veneer before I got them due to some water damage. Easy fix. Have all drivers but some need to have Richard work his magic.
BT
I've put together the basic framework for an ADS model rollcall. I know this is far from complete, but I thought it'd make a good start.
Okay,
So far...
ADS L300
ADS L400
ADS L520
ADS L-700 (early)
ADS L700 (3 way, 4 driver) 4 ohms
ADS L710-A (4 ohm)
ADS L-710 (3 way, 4 driver) (7" woofers) 6 ohms
ADS L780/2
ADS 800
ADS L810/A (4 ohm)
ADS L-810 (3 way, 4 driver) (8" woofers) 6 ohms
ADS L-880 (3 way, 3 driver) (10" woofer)
ADS L-910 (3 way, 4 driver) (staggered 10" woofers)
ADS L-1230 (3 way, 4 driver) (angled mid/tweet, pair of 8" woofers)
ADS L-1530 (3 way, 4 driver) (angled mid/tweet, pair of 10" woofers)
ADS L-1030 (3 way, multi driver) (angled multiple mid/tweets, pair of 12" woofers)
ADS L-1290 (3 way, 4 driver)- are these the first bi-ampable ADS?
ADS L-1590 (3 way, 4 driver)
ADS M-90
ADS M-90/12
I'll dig through the long (10 page) ADS post to pull out more model #s, unless you fellas write me with them sooner.
I know I'm missing some model numbers like the 12-something, and the 400.
Anyone know which units came paired with the ADS model 10/01 time delay/acoustic demension synth?
NOTE- the above is a rough outline and is not all inclusive. Please be aware there may also be factual mistakes.
thank you for the update. I have the L-520's with Bronze grill mint and the L1 mint. Recently got a pair of the MV-40t also made in Wilmington and absolutly love them with my Dynaco MK111s mono amps. I have no grill cloths for the MV-40's though. Ideas? also have the PB1500 and C1500
Glenn,
BT
I see now. I missed the "sold" in the list!
We all have a problem, according to our wives that is!
Might be Semantics but the Big boy 910 do not have an L designation.BT
As long as we are talking about ADS speakers sans L, I have a pair of ADS 300s without the L prefix. They also have foam surrounds not rubber. It's likely they were very early production around the time of the transition from Braun.
- Pete
- Pete
I also have a pair of those noel 300’s had to refoam them tried to find a proper butyl surround to work but was unable either size was wrong or the angle at the cone. Also just picked up a pair of noel 200’s these happened to have the butyl surrounds. And sound great.
Cheers
BT
I just came across a pair of MV30T's at Goodwill yesterday when I stopped in on a whim because it was next to the grocery store. I had never seen or heard of them before but knew just by looking at them they were better than the speakers I currently had hooked up to my home stereo/turntables/media server Frankensteins monster of an entertainment system. For $12.00 I knew I had found a deal
Welcome to AK, you will find many friends here.
Nice score on the speakers.
I’d be willing to bet that you will never go to that grocery store again within checking the Goodwill store.
Regards,
WN
heres my set I refinished with new woofers and tweeters. L690
PUpDFlm
Hear! Hear! (lol)
I bought mine circa 1986 and have cherished them ever since. Wouldn't consider replacing them but I do hold a grudge - they've spoiled me. Of course that was the start and eventually I added derived rear L-1290s. A set of L-470s appeared to make an office system with my old Atelier stuff. Then the TV sounded like hell (when not doing faux surround) so I put L310s on that, with a 3rd L310 for a center in the very few instances when I could decode real surround. Of coursethe bedroom really needed something listenable so in went some L-400s. Then oh-the-horror I hurt a 980 woofer and found both a replacement and an sw12 to prevent that from recurring. And so on.
Anyway had to chime in with thanks for the canonical ADS thread. I popped in trying to find a suitable "rear surround", still debating L-690s or L-990s as they have the form factor that would work. We shall see.
I think I caught a sickness back in 1986, thanks to a good friend who worked there. I was skeptical, he was insistent "You REALLY need these". He was right. I have been glad ever since. They'll have to pry my 980s from my cold dead ears.
Cheers,
- Jeff
LOL...older thread but I just bought super clean set of L570/2 and still breaking them in....but so far they sound very detailed with good tight bass...depending on music....great build quality...comparing them to my Polk monitor 5 and Paradigm Monitor 3
And whoever owns those lists, can we please get "a/d/s" fixed to add the trailing "/"? The brand (and trademark) is a/d/s/, thank you very much.
Product management/brand police, over and out.
John
Hey John,
Do you know the reasoning around the serial numbers? It looks like 5 numbers which are appended with something like 0-1, 3-1, 4-1, 1-5 etc.
My L710’s are 04061 1-5 and 04016 1-5.
thanks,
Kelly
Even though they had a colored sound I loved the 2030. It and the B&W 808 wee my favorite speakers way back when that I never could afford. Both needed ample power, too; which wasn't cheap either. Loved those 2030 domes.
