guptonr
I picked up this pair of utility cab Advent Loudspeakers (old Large Advent) a couple of weeks ago. (Previous thread: http://www.audiokarma.org/forums/showthread.php?t=292970&highlight=advent+foam). They needed to be refoamed. The foam had been previously replaced but it wasn't the right kind and size and didn't fit well. I got the new foam from R Cobb (looneytune2001 on eBay) as recommended by many AKers and it was a perfect replacement. I recapped the speakers to get them to match. They were of two different production runs. One from 1973 with fiberglass fill and two 16 uf caps and a 3 ohm resistor in the crossover. The other was a 1976 vintage with foam filling a 8 uf, 16 uf, and 3 ohm resistor in the crossover. I put new caps to make both 8 uf and 16 uf. I used Dayton caps from Parts express. I had to use 12 uf and 4 uf caps in parallel to get the correct values (4+4 and 12+4). While I was in there, I noticed some of the sealant on the inside cabinet corners had hardened and was coming loose, so I resealed it too. My next step is to make my fist attempt at veneer. I have some paper backed cherry that I'm going to use. I'll post those pics when I start on that part. Pics of progress in next posts.
One question: Does anyone know how to clean a speaker cone? These are fully functional, but have dirt dust on them that won't come off with a brush.
