I was using a DG-SE1 maggie el84 build on my cornwalls to much delight... until I recently built myself a 2a3 SET amp with electra print iron driven by d3a in triode. As noted above, the 2a3 is a little shy in the bass department, but with cornwalls sounds divine. I won't be changing the set up for a while! Lots of folks say the bottlehead amps are great, and I think they fall in your budget.
I would not be shy of going SET
SET or just single ended?
Dennis has been making SEPs again lately.
I'd be interested in his SEP amps. Just want to try single ended in general. I'm not a huge bass head myself, partially because I can't crank the bass where I live. I think I'll have to hold off on buying one of his amps until I can hear a single ended amp in person before committing to buy one.
I sourced and designed the circuit for my 2a3. I've been meaning to do a build thread over in tube audio because I really didn't find many attempts at the 2a3+d3a 2 stage amp along the way and learned some stuff along the way that might be useful for other folks embarking on a similar journey.
If interested in SEP, you could probably find a DGSE1 in barter town, or find a maggie 8600 console and mod it yourself! It's a fun project and there's so much documentation on AK (thanks all!!) that it's hard to come up with a poor sounding amp in the end. I had a great deal of fun with my DG SE1 EL 84 SEP, and main reason I stepped up to DHT was I came into a killer deal for a pair of strong rca biplate 2a3 that I couldn't say no to.
2a3 amp below, still am going to do something with the bobbins on the chokes, and maybe get a laser engraved plaque on the front of it.
Many are wrong.![]()
Price does not hurt too much and is salable if not satisfied. This amplifier cannot be built for the price it sells for. The EL34 is one great sounding tube.
https://www.amazon.com/BOYUU-Hi-Fi-Stereo-Amplifier-Single-end/dp/B07L4GL63N
One of my best friends has a pair of the Cornwall IIIs, he recently texted me that after running his upgraded, from ConradJohnson, Premier 11A for a couple of months he put his Had Inspire with Genalex KT-88s back in the system...his words are: "I put the Had amp back in the system. It is so vastly better than the CJ in every way it's amazing. I swear it's stunning the difference. The only amp I have ever heard that comes close was that big pair of spiny cube Pass (Alephs) amp you had once on your Martin Logans"...
Mike has been an audiophile and OCD level listener since the early 1970's when he had some of the early SAE silver faced gear and a set of 901's...
I would love to listen to one of the Dennis had inspire amps. They were on my short list and I was very tempted to go all out and purchase a new one but unfortunately it's just a little too out of my price range at the moment.
I found a good looking older model mini torrii jr from decware that comes with some extra tubes. It seemed like a fair price and considerin the options it came with I decided to go for it. I've heard nothing but good things about decware and the Dennis had amps and if I had a bigger budget I definitely would have gone for one of his inspire amps. The one I purchased is a decware mini torrii and its a single ended Pentode not a single ended triode but it's arriving tomorrow and the seller was really great to work with.
I also very impulsively bought an audio research SP9mkII, because the price was so good. It's been performing flawlessly and I really like the phono stage.
Why did you chose a Mini Torii over the Rachael SE34I that you were going to buy?
Are you planning to use SP9 as a preamp or just for the phono? The Mini Torii only needs 1 volt for full output.
I mainly chose it because it seemed like a better value and the seller was better with communication.
It looks like I won't be able to use the pre amp with the mini Torrie than right? From what I gather the output impedance of the pre amp is higher than the input of the amp so it wouldn't match well at all. I guess I could still use it just as a phono pre amp.
I don't know if you were aware that the SE34I was originally listed for $800, then after the seller found out that the original owner had some options added when he purchased it new, raised his asking price to $1100. The current seller knows what he paid for it and what he wanted for it, why all of a sudden did he think it was worth $300 more?
That and your experience is maybe why it is still for sale.
An impedance mismatch is not the problem, I think you will find there is too much gain using them together.
