dr*audio
Fish fingers and custard!
This amplifier has balanced outputs. What this means is that there are actually 2 complete amplifiers in each channel, one drives the + speaker output and one drives the - speaker output. This is very important! - speaker outputs are NOT connected to ground! When the amp is correctly working, if you measure between + and - speaker outputs you will have 0VDC and if you measure from + or - speaker outputs to ground you will have 0VDC. There are adjustments for this. If you attempt to perform the adjustments and don't get 0V, Do not connect speakers!
When probing with a meter probe, put electrical tape around the probe tip so only the very tip is exposed. This will help prevent what happened from happening.
Test all the output transistors on the bad channel, then test the drivers. Keep going until you stop finding bad transistors. Then replace the bad ones. Also replace ALL the outputs on that channel because you don't know if any of the others may have been stressed and damaged.
