Low impedance speakers are not better than higher impedance speakers, and can eat amps. I think they are an affectation, like using a monocle or wearing spats, and in worst case simply wagging around that fact that someone is spending lots of money since speakers that have impedance dips approaching a dead short require giant expensive amps (and even then blow up often).
Volume is not quality, louder is usually the opposite of "better sound", and wattage required isn't directly related to sound output. The difference in output wattage with 4 ohm speakers is usually waste heat I think, since the current draw is much higher. Hot heat sinks and roasting voice coils isn't an improvement to my way of thinking.
4 ohm speakers aren't going to give you better sound than 8 ohm speakers if they are both well designed (and I have my doubts about the design of speakers with impedance dips approaching 1 ohm!). Buy what sounds good to you.
And keep the SPL well below 85dB unless you like being deaf.......
