phantomrebel
Serial Tapist
The instructions on their website do not mention this (https://spincleanrecordwasher.com/instructions). Maybe the ones that come with the unit?IIRC, from the instructions.
My research has shown the fluid to be a mix of SDS (anionic detergent), polyaluminum chloride (flocculant), and a preservative (identity unknown). I'd be very interested in whether they are now including enzymes in the mix, as they wouldn't remain very active in the solution, particularly in their storage protocol.
In any event, the system the OP is using is clearly not working properly. Time to change it up or completely go another direction.
Good Lord man, you're not cleaning you're records, you're applying dirt to them! First don't EVER let you're cleaning solution get that dirty. If cost is an issue (even if it isn't), use a DIY solution. That dust bunny built up around the stylus is your answer. NO, your records aren't clean yet. If you aren't vacuuming the solution off after washing, you need to rinse it off. I let my records air dry after cleaning but not before being wiped with a clean microfiber cloth.
