After reading here how about how important it is to clean your records I ordered a Vinyl Styl Deep Groove Record Washer system from Sound Stage Direct on Cyber Monday. It cost $59.99 which was $20 off the regular price. I compared it on line to Spin Clean and decided to try the Vinyl Styl version because it has clamps that cover the label. When you turn the record to clean it, the record hangs in the tank by the plastic fingers that protrude from the label cover clamps. It's very easy to spin the record and it's very stable in the tank hanging from the label clamps. See link below.
http://www.vinylstyl.com/accessories/vnst10060261-vinyl-styl-deep-groove-record-washer-system/
After cleaning a few records and letting them sit in the included drying rack to thoroughly dry, I started playing them. The records looked clean and shiny and sound great with few or no clicks and pops. However, when the third record started it sounded bad and I could tell the stylus was dirty. A sizable dust bunny had built up around the stylus which I easily removed. The record sounded great again. I started checking the stylus after every couple of records and found gunk/dirt or something had accumulated on the stylus. This rarely happened before. If the records are in fact getting clean, should this be happening? The cartridge I'm using is a Shure V15Vmr with OEM stylus. Beside the stylus collecting dirt, the brush also had some dust on it, though not much. Note that the stylus on these cartridges are very tiny and ride deep in the groove.
Prior to getting this device, I used a Disc Washer brush without using the cleaning fluid to clean the record and used an In The Groove Roller to pick up the dirt that the Disc Washer brush left behind, in a line.
I'd appreciate reading some of your thoughts here about this.
Thanks.
