I've already posted this image set. I'm just linking to them here for the tale I'm about to tell,...
This is looking down my long shot. In the opening, you'll see two shadows near each other. This is near the center of the image. One is larger than the other, and closer to me.
The other is smaller, and a bit more distant. That smaller shadow is exactly centered in the image:
The smaller shadow is caused by this drooping branch, which creates a small framed area, with shadow on one side, and bright sun on the other side.
The squirrels cannot resist framing themselves in this little window. They stop right there, and, performance whack-a-mole plays out again, and again,....
My tale from today is at this same area, but, is from the area above the drooped branch, immedaitely above the drooped branch, and where that branch goes back into the main shrub, to the left; there, you'll see more of the sunny backdrop. That area immediately above the framed droop, and behind it, up the hill, is where todays rodent was popped.
OK,... so what, another dead rodent.
What makes this somewhat unique, but, absolutely mind-boggling to me is that I saw the pellet, intensely clearly; so clearly, that I could identify it as a skirted pellet, and because I know what it was, it looked very clearly to be an H&N Barracuda Hunter Extreme pellet.
I saw the pellets final moments of its trajectory, at such an angle as to be able to see enough of its side profile to see the shape.
When I saw the pellet, I saw it for long enough to have thought,... MISSED. I thought I'd missed it because the pellet was still droping in on the target. In that exact same moment of thinking MISSED, the rodent just exploded, twisting around for about two seconds, then dead where it was popped.
OK,.... this old psychedelic hippy was blown away by seeing real trails, man (in his best Tommy Chong voice).
I started the day out by whacking the shooting stick, and saw that pellet hit too.
My last several days have been spent hauling dirt to fill an old swimming pool; 42 buckets yesterday. I have to lift the dirt up to a 3' high pad, with no access, so buckets it is.
I was tired, and that shot totally energized me.
When it finally got to be too warm to haul dirt, I hauled my heiner down to the squirrel to see what went down. The shot was dead on point of aim. It could not have been any better.
I aim for just behind the shoulders, as shots across there are across the lungs and heart. They are near instant kills. This one was dead on point of aim/point of impact.
So, this is my long distance shot, as seen from the impact zone.
Yes, I did go see the rodents carcass. Had to.
My 250' shot is down this dirt "road". My angle is closer to diagonal across from the treeline on the left of image. There you'll see a power pole rising up:
My western perimeter outpost, my long shot, is just to the right of the base of the power pole, about 5' higher than the base, above the shadow line:
The rodent emerged from these holes, which killed this tree stump (its what they do). This dead stump is just to the immediate left of the framed droop that the rodents pose in for my shooting pleasure:
This is the western perimeter outpost:
This is the new and improved perimeter outpost. The first one was like this, but, the wood was rotten and full of termites. So, it went to the dump, and this well seasoned, clean firewood was hauled from the outback, and, stacked here for the next splitting.
And, this is the rodent of the day, and, exactly as I found it.
left image is as found - right image is to see where I whacked it.
This is one immensely fat ground squirrel (Beecheys Marmot).
