In my research, I found the Beeman Chief 1322 .22 caliber PCP single shot, entry level rifle (read: buildable ready). My parameters were actually quite challenging, as it turns out.
I bought this Chief rifle, new, a few months ago now. It has been a challenge to figure out how it shoots, to say the least.
By challenging,... I mean trying to get it sighted, and, for that sighting to stay consistent.
gotta run,... gonna post this for now, and will follow it up later,...
I guess this might be my review of the Beeman Chief .22
When I bought the rifle, I took it as it came, with its supplied open sights, no scope. I sighted it in using the iron sights (actually metal framed fiber optic rear and front sights). The gun sighted in at a low "6-o'clock" sighting, with a larger gap at 6-o'clock. it was very well centered, but a low 6 o-clock sighting.
I didn't spend much time with its open sights, as I had already ordered a scope for it, and was awaiting delivery.
When the scope arrived, I tried zeroing it, and was able to get to center quite quickly. But, there was a problem,... the scope was very erratic.
By erratic, I mean, I got it well zeroed, and whacking center. Then I'd need to pump the rifle up again. In doing so, and in returning to shooting, it was as if the scope had been completely scrambled, and I'd have to start over again in achieving a good zero. By the time I was zeroed again, I'd have to pump up. When I pumped up again, the scope was acting completely scrambled, all over. WTF?!?! It was a viscious circle.
I gave up on that scope, thinkning it was just a cheap scope (it was), and that I needed to get a better scope (I did).
I bought and mounted a UTG BugBuster Accushot AO
I zeroed the scope, and, the results were exactly the same, as just described; find good zero > need to repump > scope settings getting scrambled.
This was getting maddening.
I finally resorted to joining a blog at PyramydAir.com I found that blog via a search for the Beeman Chief. The blog is written by a gent with the moniker of BB Pelletier, aka, Tom Gaylord. As it turns out, Tom is a world reknowned expert on air guns, dating back to the 60's. I also saw him on a cable program titled American Airgunner, in a discussion panel.
He reviewed the Chief, and, had as a scope, the UTG BugBuster Accushot, and was all about the combination.
So, I explained my circumstance, that I had topped out with the adjustments wth two scopes; meaning adjusted them to as high as I could go in an upward elevation direction, and had the adjustments hammered hard up at that level.
He explaied that any scope that is pushed that far is like a clock spring about ready to uncoil and explode; and in fact, that is what was happening to the scope.
Unknown to me, I had taken the internal sighting tube, and, pushed it far beyond its extremes, and the slightest jarring was causing the scope to go completely out of adjustment; read: any time that I went to pump the rifle back up to pressure, that action of setting the rifle down was in fact scrambling the settings.
He suggested a bent barrel, and, I concurred.
I went to Beeman, and, with the assistance of Peter the tech, we spent several hours tearing the gun down into bare components, and checking every single piece and action. This included rolling the barrel on a granite measurement table (milled to the millionth of an inch to true flatness). The barrel rolled true and straight; not bent.
Peter found that my safety wasn't to his liking, so he replaced the entire air handling bits, trigger mechanism. The only original parts that my rifle had after our visit was the barrel, and the stock; all else replaced. Beeman was great!
So, I get back home, and, sight the scope; dead on. I go to pump it back up, and, the scope settings go to **** again. WTF??
The scope is still bottomed out, and needs to be able to be adjusted upward to free up the sighting tube,...
I go back to PyramydAir blog, and, post again of my circumstance. Tom picks back up on it, and suggests that the barrel, while rolling straight, might be drilled not true to center. He suggests a syndrome called Drooper, or drooping barrel, which I guess happens with the break-barrel design as the locking spring weakens over time.
Tom suggests that he worked with the UTG people to create a forward sloping scope mount that points the scope downward to follow the drooping barrels of a particular German manufacturer.
He referred to my barrel as a drooper, but, it is not a break-barrel, it just focuses forward and down. My barrel is fixed in position by an aluminum collar that locks the barrel to the air reservoir tube. More on this aluminum collar later,.....
So I bought the adaptor that Tom had designed for the Diana rifle, and, fitted it to my Dovetail rail. The adaptor is a Dovetail to Picatinny adaptor, and canted forward such to give 10" of elevation lift at 90m
I went out, and, I was able to drastically reduce the elevation turret to be far lower, and closer to the opposite end of the adjustment scale, but, still within adjustability range.
This brought stability to the scope, finally!!
I can now adjust the scope, and, it stays zeroed! This was like climbing vertical mountains to achieve.
The aluminum adjusting collar,...
It is as a standoff between the barrel, and keeps the barrel and air chamber parallel, and keeps the barrel centered. It is held in place by a series of small set screws.
After I got back from Beeman, I found that I was pulling slightly left. I compensated by scope adjustments. Then one day, I loked down the barrel, and found that it was not parallel to the air chamber, which is seated in, and parallel to the stock, and it supports the barrel. It appeared that the abrrel was just a couple of degrees from true parallel, which would cause pulling. So I marked the collar and air chamber with tape, and fine marking pen, to be able to return to the beginning point, and I moved the barrel back to being better centered, by eye. The scope needed to be adjusted to compliment the change, and the pulling went away.
OK,... does this sound like a love hate story?
I love the shooter. I've tweaked it to be a really dialed in shooting iron.
My only real complaint (I actually ahve another) is that it is loud; but that can be made to be different.
The bluing is near worthless. I've turned a surface brown patina, despite regular maintenance.
The PCP format is a pile driver. It operates between 1k and 2k lbs of pressure in its onbard tank. This thing loves its heavy pellets! My next pellet selection will be
25grain slugs that hardly resemble skirted pellets.
I zeroed the scope using some 14grain cheap pellets, to get me on paper. I changed to 18grain hollow points as my go-to slugs. Then I tried some 21 grain pellets, and the group flew consistently 4 inches higher than the 18grain slugs.
I took that high grouping to my advantage a couple of weeks ago now, and, I went long range.
This is prety much where I'm at with this.
I'm building up a taller cheek weld pad; I'm tall, with a long face. I need the added height, but, need to bring the cheek up. I'm going to wrap it in leather, and leather lace tie it to the stock.
You can see the forward canted Leapers/UTG dovetail-picatinny rail adaptor, ^
