Not if I can't see Dave's design, I'm not....Zilch, are you going to have a mock up by next Saturday?
I see it this time, Dave, aqua and black, with the HF chamber at the lower left, dimensionless. It's the configuration you're illustrating, and I assume the volumes remain as you earlier suggested?I'll try attaching another version of it, with less exacting dimensions to give you an idea.
Yes.So we're talking 4 drivers, 2 per side in a PP arrangement in a 6th order (all chambers ported to outside) BP box right?
What does the 2 driver/2 chamber look like at 100W? PE has a 100W plate amp on sale right now. I'm guessing plenty for an under-desk powered sub to compliment computer speakers.
Because of the ability we have to use transfer function to our advantage, i may try to tweak for a upper bass peak with a shallow rolloff to gain some system efficiency.
You might be able to make a general guess...maybe around 50Hz or so? That would put you in the right neighborhood (~20' longest dimension in the room) and you'd start gaining below that.
Ray
Well, you can play here, too, then.Keeping an eye on this... I just discovered I HAVE a pair of '1139s, here, new in the box!
Dave, one thing to remember, is that you need to provide driver access, for both drivers, somewhere. Having the driver be stuck in the box could be bad, if there ever is a problem with a driver!
The easiest thing, with the drawing as you have it, would be to have side of the box comprising the longer of the two sides of the small chamber (i.e, the left side of the drawing as oriented in the picture above), be removable... that would allow both drivers to be removed, easily...
What kind of dimensions are we looking at? Looks like maybe around 16x16 by something? EDIT: I see the dimensions... duh. That's kind of large... almost 27 x 22?
Keeping an eye on this... I just discovered I HAVE a pair of '1139s, here, new in the box! I was going to do something similar in my truck, for bass... but wound up using the space behind the seats too much, so I gave up on that...
Regards,
Gordon.
