"As I said - CHECK YOUR CONNECTION - your ISP may be having issues. There are issues there. If you don't check that, just blaming AK is utter nonsense"
post #19
My ISP insists that my connection is good and it must be AK, If it was my connection then I would be having the same problem with
www.VideoKarma.org as well as the AK data base, both work fast, It is only
www.audiokarma.org that is slow. This has happened in the past to other AK users but I don't know how they resolved the problem, this is killing me, the only way I can use this site is with a proxy server that makes AK do weird things but at least it is fast.
The same thing happened to Echowars a few years back but I don't know how it was resolved
http://www.audiokarma.org/forums/sho...pianfully+slow
"There is a whole lot of equipment between you and AK. If one router has an issue (like dropping packets, long response time) there is your delay."
from post #21
I pinged
www.audiokarma.org with 0% packet loss
"Those other you mention all are from the same ISP (AK, AK DB, VK)."
and AK DB & VK work perfectly, this is why the whole thing doesn't make sense. Wouldn't I get to VK and AK through the same HOP's ?
