Homer4beer
Well-Known Member
Hi guys,
I've spent considerable time so far trying to work out this problem before posting here. Using an oscilloscope I've traced the signal loss through to the MFC PC Board on the amp. When tracing the signal off this board there is a right signal but no left signal.
Numbers 21, 22, 23 and 24 on the diagram go to the tone control board which them goes to the Filter PC board and then on to the Main amp board. There is signal from 21 (R Chan output) all the way to the main output board (hence having sound) but nothing from 23 (L Chan output).
So having traced the signal loss back to the MFC PC Board I'm having difficulty working out where the signal is now coming from with all the SW switches. I find these very confusing. The amp is going to be quite difficult to work on also with the tuner module as part of the same board.
Can anyone suggest where to go from here? I've tested the R92 resistor which is fine but now I'm stumped.
Thanks guys
Thanks guys
